Hallo, wo findet man eigentlich aktuellen Gapps und SU?
SuperSU
https://www.android-port.de/index.php?threads/5076/
GApps musst du selbst suchen, da gibt's zu viele um die auf dem Weg zur Arbeit für dich raus zu suchen.
Banks GApps, Slim GApps, Open GApps sind die am meisten genutzten GApps denke ich.
Gesendet von meinem Nexus 6
Yep, I use Open's now.....I can only dev so much stuff and GApps are the least important so I dropped that.
Pin / Pattern is squashed....next build it will be working.
This is another fairly large update coming so I wouldnt discourage you from clean flashing and for sure at least wiping system and Dalvik. This has updated clang, GCC, kernels, global -O3 (what broke camera load build), more child JIT changes, some master branch merges, and of course fixed pin / pattern. I'm not sure When Mikaole will get to uploading it but Ill have it finished in the next hour or two.
Is anyone even using this on HH anymore?
Hi Chad, I am still a happy user of Velocity on HH! The latest builds are so fast, I have no complaints at all.
Sounds good. It's just so quiet in here I wanted to make sure I'm not building for no one is all. Glad you're enjoying it.
XD I'm using it too ![]()
Love it btw
