Stock velocity everything is fine
[ROM] [M] [6.0] Velocity Hammerhead
Clock and battery text tinting on white backgrounds should be fixed next build. Not sure about other apps yet.
Great! Does stock kernel support f2fs?
Wysłane z mojego Nexus 5 przy użyciu Tapatalka
New build
i thought Chad Drop the support for N5 and was thinking about to switch to OP3
No, I was on holiday then I had a bunch of issues with my clang chain.
Hello Chad, welcome back.I am having issues with the call audio again with new build so had to go back to july 22 build. Can you look when you have some time.
Cheers
Sent from my Nexus 5 using Tapatalk
Yea...same commit likely needs to be reverted after update. I'll look. Easy fix if so.
Fix from before is still there so something else is causing this after the update.
Ok i will do a clean flash again on the second nexus 5 in office and confirm.Thanks
Yea, I dont see anyone else changing anything after the last kernel update.
Installed latest build... OMG, this ROM is so insanely fast that I don't know what to say... It's not only fast - it's also crazy smooth. Also, no problems with audio. Even my favorite Substratum theme works without problems! I have to say that I'm using custom kernel, but that's because I use f2fs and I need few features that are not included in stock kernel. The most important is that my phone flies and it's completely stable. This ROM is really amazing and I hope Nexus 5 will be getting new builds for the long time. Because this is great device and great device needs great ROM.
Thanks for the kind words. F2FS is a gimmick though and I wont touch it. HH will receive support as long as Google supports it. Unfortunately, I think that wont be much longer. I doubt HH will see N.
I saw someone Post a Link for Hammerhead what have something to do with N but I'm a Noob so I don't know if it's true or not ...
Unfortunately Nexus 5 won't get Android N. That's shame... This ROM shows how fast this device can be and it could handle Nougat for sure.
Well, I don't have good news
Call audio is totally broken, I can't hear anything. I didn't check it yesterday, I just tested media volume which is fine. While I use custom kernel (updated), it looks like it's a ROM issue. But if someone could confirm that on stock kernel, it would be good.Wysłane z mojego Nexus 5 przy użyciu Tapatalka
Edit - I can see 08/08 build on AFH. I'm on 08/07. Does 08/08 brings any audio changes?
The only changes on either new build were just the August security updates and toolchain updates. No idea what would cause that. Not sure how much time I'll spend looking into it either.
I will just try out july build then
Test build using different binaries.....
Great! Will try tommorow. Speaking about that... Sorry that I'm asking, I'm a noob in development stuff, but in updater-script of latest build I can see:
Zitatui_print("Target: google/hammerhead/hammerhead:6.0/MOB30J 2775141:user/release-keys");
while in other ROMs, for example CM the number of version is newer:Zitatui_print("Target: google/hammerhead/hammerhead:6.0.1/MOB30Y/3067468:user/release-keys");
Maybe that's nothing to do and doesn't make any difference but I'm just curious
I just havent updated the fingerprint is all. Its a fairly meaningless thing. I'll get around to it at some point. I build for me, so I dont get hung up on things like that.
