ctfromm what do you think of use pushbullet to notify the users when a new build is out? Thanks
[ROM] [M] [6.0] Velocity Hammerhead
[emoji23] thrilling [emoji7]
I like to think adults can keep track of 1 folder.
New gapps
mini, minimum, standard version available
Ok, all 3 New Gapps packs are up. Clean flash is mandatory. Please read the changelog...one time only make sure you not only factory reset, but also manually wipe data and then unmount before flashing GApps. New Play Services causes a log in loop for some if you dont. There is some new security check related to them or something. Again, this is ONE TIME only! All subsequent flashes are fine.
Did a clean flash with 22.10. Gapps (mini). All fine.
But today I only wiped system, cache and davik cache, unmount system, install rom, install 23.10 mini Gapps and superSU and still had no play services.
So,...not "one time only" or are there other reasons?
Other reason... I made some substantial changes to gapps again that will likely need a clean flash to resolve this.
Ich love to open apps in velocity
so buttery smooth and snappy. And great battery life!
Hello. Thank's for interesting rom. I really like it. But I have one question: May you add Layers 2.1 support. When I use a dark theme I see a some bugs: black text on black background in contacts and not themed action bar in dialer. But this theme perfect work in another rom (no dark text on dark background and GoodContacts).
Read op...... "velocity hat nicht viele Features und es werden auch nicht mehr viele dazu kommen. Also fragt bitte nicht danach"
Englisch :"velocity hasn't much features and won't get much more. So please don't ask to add features "
Velocity will NEVER have layers....Google saw fit to add RRO into Marshmallow source or there wouldnt even be that. The night mode is Googles code, not mine. This is exactly how it worked in the preview before they decided to remove it.
Any update?
No, chad is redoing all features. Will take a bit more time
In redoing all features, adding a bunch more, fixing a bunch of irritating issues, polishing all aspects of the OS, and fixing GApps. Dirty flash issue with GApps is a thing of the past. Took me a while to figure this out, but I think these will be the only GApps (AFAIK and have tried) that dont have this issue with Play Services not properly installing. All this was a HUGE chore and will make for a much much better user experience all around. Testing of a pre-release build has just begun, so if its all good you guys will have it tomorrow. Make your backups as this will be a clean flash all around. Gte rid of any old GApps you have and make sure and grab the new ones of your choice when I release them.
The latest AOSP update (6.0.0_r26) is causing major issues while attempting to merge. I think Ill release V3.0 as is for now (I intended on adding more and merging r26 first) and then go from there. Its looking like Ill have to start completely over as I cant even get a booting build right now after a full day fighting this merge. Im going to check with my testers and see if there is any reason not to release this. Next build after V3.0 may be a while.
V3 und neue Gapps online
Clean flash empfohlen -
Alright, I tamed the savage beast that was 6.0.0_r26....All features from V3 work again and I even conquered the major bug with the microphone not working that all roms that updated to r26 are experiencing. Going to start testing and hopefully release a new build in the next 24 hours or so.
Master [emoji119]
V4 online und neue Gapps online
