Does this rom support layers or theme Cmte ?
[ROM] [M] [6.0] Velocity Hammerhead
No issues here ... Id never upload something that broken. Must be that "other" kernel causing it
All Marshmallow Roms support layers....Id never add anything related to it myself though...especially CMTE
[QUOTE = "ctfrommn, post: 152551, Members: 2957"] All Marshmallow Rome support layers .... Id never add anything related to it myself though ... Especially CMTE [/ QUOTE]
Wow, that was fast
It's a shame that you can't find information about this rom, except this forum. I had hard time finding it!
Anyway, downloading! I am gonna flash it tonight!
It Should be hard to find .... I've been down the popular rom road and want no part of that again. I want to say, Velocity is unlike any other you Rome youll find. This is a use it as it comes affair though. I have no interest in changing anything. This is my personal Rom I just happen to share.
Not all people can handle so much zpeex, that's why it's only here:)
Much people will ruin this rom with their "add this or verz good rom but...." They can't be happy with that what they get xD they need MORE ! Little finger whole hand ect
People are just used to Rom development being a certain way....I just dont choose to do it that way as I have a different agenda. Its not better or worse, just different. If I wanted popularity Id be on XDA and advertising this everywhere
Well ... New build every 12 hours? [emoji14]
Is the latest security update merged with this build?I flashed the previous one and I had a problem with the SwiftKey keyboard (with A Certain theme). I changed the theme and everything works flawlessly!
Sent from my Nexus 5 using Tapatalk
Yes ,latest security
Inviato dal mio Nexus 5 utilizzando Tapatalk
[QUOTE = "mikaole, post 152 568, member: 2206"] https://drive.google.com/file/d/0BzX_bR…sp=docslist_api [/ QUOTE]
Will dirty flash work? -
I never flash dirty, but you can try.
Use rom settings backup and clean only take about 10 to 15 minutes -
Rom setting backup? What is that? [emoji14]
I use titanium backup and it takes 30 minutes to make everything like before[emoji14]Sent from my Nexus 5 using Tapatalk
Wow. Thanks. I didn't know about that...BTW here is the problem with the SwiftKey keyboard.
Yep, dont expect it will get fixed. I dont use it. Swiftkey has always had issues.
Actually not for me. First ROM I encounter this issue. -
Then you know the solution
Which keyword do you use?Sent from my Nexus 5 using Tapatalk
