Always AOSP
[ROM] [M] [6.0] Velocity Hammerhead
@ctfrommm
You have done great job with the rom! It's the best rom I have ever used for my nexus 5!It's stable af and smooth as butter! The battery life is more than good and I couldn't be happier!
Unfortunately, I can't update it every day . At least, could you provide a changelog with the updates?
Finally, can I talk about this rom in g+, just as a recommendation ?
I am asking you because I know that you don't like the publicityKeep up the great work!
Sent from my Nexus 5 using Tapatalk
Hmmm, let me think about that for a while......no
As mentioned n shamu thread no changelog anymore. Chad has no time for it and since all features are included there is no use for a changelog because all whats coming are optimizations and most of us wouldn't understand what the changes are.
it's look like a nightly build...
i'm so busy to flash this rom nightly hehe -
It's always been like this. It was just never shared this often before.
Sometimes we even got hourly builds:)
The nexus 5 isnt your daily driver ?:D
No, I never use it anymore. I flash a build here and there to make sure they work but that's it.
Which is your daily driver?
Shamu
I'm use today's build, I use a viper 4 android 2.3.4.1. but I turn up a analog x and clearlity setting (I'm use a viper korean translate so I can't check this function name) I can hear popping sound.. can you check this..? and elementalx kernel solved this problem...
I'm always thanks you make a nice rom -
At my side with Viper there are some "crackers" when listening music. Changing CPU min frequency up tp 622 mhz solved this.
Try it. -
I don't use viper so don't care. There is nothing wrong with the ROM audio. I don't support mods.
Don't care. It's your baby. I'm so happy that you share it with us just as it is [emoji2] [emoji106]
Shamu
Faster than hammerhead?
