Not really, I use opengapps as well. Try to reboot if you haven't done that already.
mikaole -
24. Oktober 2015 um 09:17 -
I tried also the latest version of open gapps some days ago but it doesnt solve it. When maybe today a new version of the rom will released, I try it again with the latest gapps. -
try wiping data and cache of play services. -
Try deleting app cache and reboot
Play services issues is 100 % related to some Google app. Id start with just clean rom and core gapps and see if you have any issues. If not, start adding the additional Google apps you use back into the equation. I suppose you could start freezing them as as well till it stops. The biggest offenders are search (specifically using location history) and G+ so I'd start with those.
Everything anyone mentioned works correctly again
Yeah! Can confirm that all SwiftKey themes are working fine now! Thanks for the fast fix!
Guten Morgen. Könnte von Euch mal netter weise den Kernel zur Verfügung stellen.:)
Kann ich machen, aber wie mach ich das?
Habe jetzt die boot.img aus dem ROM zip extrahiert und hier hochgeladen, ist das das richtige?
https://drive.google.com/file/d/0Bzr7_J…sp=docslist_api -
Danke Euch:)
Und hier der aktuelle Kernel
https://drive.google.com/file/d/0B__yyN…sp=docslist_api -
Hui, und schon wieder ne neue build, gestern nacht erst die letzte geflasht.
What are we using the kernel for? It's definitely not designed to work with other Roms. That's why I don't make separate kernels.
It's the best kernel out there:D
All roms I tested were better with MVK. -
Great job with the latest version. Have no problems [emoji106]
