well it actually happens on all builds i used so far. and now im on latest.did you try hearing music on landscape mode and then rotating it by 180°? One time it is louder from the left and the other from the right. it may by my hardware but i hope not.
mikaole -
24. Oktober 2015 um 09:17 -
Just tested and they both sound the same. If I rotate it to landscape and put my nose in the middle of the screen it sounds like perfect stereo. You may simply have crap in the speakers did needs to be cleaned out.
Man I just realized that you modified the bcl driver to re-enable the cores and ramp up again from 1.9 to 2.6. You are a true genius! Respect mate
No idea what youre talking about.
Ok, so I searched what a BCL driver was and I definitely havent touched that, though I will now. thats an incredibly irritating "feature".
What's that Mikaole? AFAIK I didn't build 2 today
Oh thats strange. Because on stock and other kernels the bcl driver kicks in after 60% battery and under certain circumstances it limits the cpu to 1.9 until you reboot or charge the phone. On your kernel it goes back to 2.6 again thats why I was suprised. Since you are going to mess with that, I want to tell you that by removing that, it causes the phone to reboot when the battery cant supply enough power to the cpu.
I removed all the crap from thermal crap from the kernel/ramdisk a long time ago which is likely why you saw what you did. But at 25-30% left it does/did change over to 2 cores at 1.9 max. Thanks for the heads up as well....if rebooting becomes an issue with lower battery Ill revert it.
yeah I noticed the 2core thing. but after a bit it changes to 4core again so its all right.
about the rebooting, i meant that it will eventually reboot if you remove/disable the bcl driver. now all is working absolutely fine. -
Yep, I got that. I meant I'll keep an eye on it going forward now that I disabled it.
Es wäre ja mal schön zu wissen, was sich in den neuen Builds ändert oder was neu dazu gekommen ist.:)
Meistens einfach "Optimierungen", neue feature kommen bei Velocity nicht mehr dazu.
Mostly "optimizations", as there won´t be coming any new features to Velocity.
So ist es [emoji2] [emoji106]
I'll let you guys know when there is anything major or truly interesting that is changed. I'd have to be truly impressed to consider adding anymore features. I havent seen anything out there that I feel that way about right now. My focus currently is to improve clang implementation, constant updates to both toolchains from the respective master branches, and any kind of fix or improvement to current code. I still do lots of aosp master merges and add commits from there when I see something worth my time. These last few builds have had a lot of under hood changes and the next several will likely as well.
Next build, big changes, really fast....
Since M is asleep......
https://drive.google.com/file/d/0BzX_bR…iew?usp=sharing -
So is the new build based on "N"? Should we clean flash / update Bootloader or do anything else? Or am I misinterpreting your post?
I think with M he means mikaole -
Rofl, ok
EDIT: Dirty flashed wiping system, cache, dalvic and all working fine so far.
