It was my fault, Chad mentioned [emoji27]
mikaole -
24. Oktober 2015 um 09:17 -
I dont use layers ever so I dont keep track of the commits. If you have commits for this Ill look at it.
I've spoken with fraz14. His git is up to date.
You can have a look into the layers commits there [emoji2] -
Layers commits exist in lots of repos. I added all the layers v4.0 commits a while ago so if there are newer ones then that Ill need to know exactly which repo theyre in.
Ok, v2 will be done shortly. Fixed the missing "post" button in hangouts and added a bunch of new layers commits (thanks Fraz)
You're my hero. Cheers [emoji482]
Where are you getting the cool emoji's?
Tapatalk app
The only thing in this crappy app that's good [emoji6]
Ahh, yea I havent used that in years.
I'm still using it to be able to handle 3 different forums
As long as one of them isnt XDA
Touchee [emoji32]
But there were times I've used it much more frequently
The missing post button was a little bit crazy:D -
Lol ... that doesnt even make my top 10 oddities since I started building full clang. There have been things that have taken me 2-3 full days to track down. That said it would have taken me a lot longer to fix this without your help. I added like 100 commits a bunch of repos today.
Yeah. On Locksrceen there's now everything OK with layers in ambient display [emoji2] [emoji106]
So fun new feature in this one.....Speed dial options in the dialer. Long press any number and set a speed dial option for it.
