mikaole -
24. Oktober 2015 um 09:17 -
Next build .... updated Webview, updated Adreno drivers, updated toolchains
Moar speed coming ..... Polly (clangs version of graphite) optimizations were not being properly included .... this shoulderstand get stupid almost
This is turning out to be much more difficult than originally thought...this may take a couple days to finish
Ok, I mostly have this worked out now. Look for a build later today.
Next build ....
Updated toolchains / kernels
Global Polly optimizations
Updated sqlite database
Couple minor fixes -
About time, mate!
Just kiddin´
Hmm, not sure I'd flash an April 1st build.
I tested it. Don't flash it. Not worth it. Damn slow.
This is my first build of my transition to maximum Mediocrity Project .... it will most certainly be usable and mostly decent at everything.
Are there the just released April updates from Google included?Applying a Device OTA Image
ctfromm, since you removed the bcl driver i have been getting reboots under 20% battery. mostly when recieving a call while browsing. i will try the latest build and if it happens again i will let you know.
Kleiner Bug bei der Velo von gestern (vielleicht kann jemand das für die aktuelle Version bestätigen?): nach wählen der Nummer beim Telefonieren wird das Display sofort schwarz und geht auch nicht wieder an, wenn man das Handy vom Ohr nimmt. Drückt man Power bleibt es schwarz, drückt man ein zweites Mal geht es an. Das Display scheint also an zu sein, man sieht nur nix.
English (for Chad
I just came across this little bug in yesterday's build: in the phone app when calling someone the display goes black immediately after dialing a number. When moving the phone it doesn't come back on. Only after pressing power twice the lockscreen appears. -
Das hatte ich auch schon bei den vorherigen Builds.
Edit :
Mit der V2 habe ich es nicht mehr. -
Cant reproduce did and have never seen it.
[QUOTE = "adl, post: 154309, member: 2823"] Are there the just released April updates from Google included?
Applying a Device OTA Image [/ QUOTE]
There isnt even source for that yet, or wasnt yesterday. -
