mikaole -
24. Oktober 2015 um 09:17 -
Latest two builds I can't access camera. (using snap camera). Anybody else has problems with this? Was running perfectly fine with the build from April 13th.
Just installed it and everything fine here.
You mean snap camera hdr? -
Yes, Snap Camera hdr. Didn't clean flash, just wiped system, cache, dalvic. Still never had problems that way. Will try clean flashing when I find time and report back.
Works fine for me...no clean flash. App opens and takes pictures just like any other camera.
Thanks, so somethings botched on my side.
Clang + Polly (especially the way Ive implemented both) are going to be prone to breaking stuff. This is life on the bleeding edge. All of this makes for very touchy situations that need to be closely watched. The faster its noticed the easier it is to fix. If I can reproduce it thats even easier.
Clean flashing helped. Snap Camera works as expected.
Dang, Snap Camera acts up again (dirty flashed coming from the previous clean flashed ROM). No idea what's happening. Maybe time for ultra clean flash with going back to stock and start from there.
Next build....clean flash for a truly spectacular experience. Dirty is fine though too. Should be up shortly.
ctfromm did you use gcc 7.0 for the rom as well or anly for the kernel? because the latest release is absolutely sliding like butter. whatever you did good job man keep it up.
Rome is built with Clang...speed is just different combinations of optimizations.
