Kernel is done, and fantastic but now Im having issues with my clang chain. Hopefully I can sort this out today.
mikaole -
24. Oktober 2015 um 09:17 -
Here is a log (hopefully the right one because the logcat showed nothing) from a random reboot that happened yesterday. This happens almost always randomly below 50 percent of battery while having cellular data active. Of course a clean flash with latest banks (happened with open too). This time I had a mod installed but It happened before that too..
Unfortunately logs are meaningless to me. Ive never seen this behavior though so I can only assume its your device.
Yep thats what I was thinking.. I thought about trying to return the device but they would make me change a billion settings before that.
The fact it only happens below 50% is whats really suspicious. Sounds like a bad battery or something. Just flash stock M and send it in if you want it replaced. Or move on to Marlin like Im planning to do.
I will most likely move to the new one
I could not see the OMP thread for bullhead so I ask here, is there a bootable version?, I have flashed 17/16/15-08 zips with and without SU and no one finish boot :jaded:
Any help will be appreciated. -
Many users are using it successfully. I think those that cant boot this is because theyre encrypted, but as I dont own the device I cant verify that. It absolutely works though or I wouldnt continue building it.
Ok, so I just got conformation from one of the BH users. He was on N, encrypted and when he flashed OMP, no boot. So he went back to a working Rom, decrypted and all was well. No idea why encryption would cause an issue like that, but this is master so anything is possible.
I will try to download and older version to try. I have velocity in my hammerhead and it is fast like the light. Thanks for your work!
Has nothing to do with the version....all builds work fine for those that can boot. You need to decrypt first.
What .... decrypt, how I can do that?
I found it, I will try and report, thanks!!
Done! My bullhead is fighting with the OMP system :P. Thanks!!
Running Omp on my Bullhead now too! Yes!!!! Thanks for your help to decrypt my N5x.
Flashed new velocity shamu build and it seems really fast. Is there the new kernel?
Inviato dal mio Nexus 6 utilizzando Tapatalk
Hey ctfrommn, francos latest r50 for nexus 6 fixed an old bug where after bcl kicked in and cpu 2 and 3 went back online, they would stay at max freq. I noticed that on yours too. Just a heads up
Cool, thanks. BCL is one of the stupidest things Ive ever encountered. -
Sorry, have you included also Linux updates for Hammerhead kernel?
Is there a HH kernel out there for M that's using a Linux version higher than stock? I see lots of really old commits, but merging those is much too difficult and merging straight from kernel.org source is equally hard. If I can find a relatively easy way to do this I will, but with N coming shortly and HH likely being dropped its not worth my time to struggle with this.
So are you thankful or was that ironical? xD
Uber kernel is using latest 3.4.112 version https://github.com/Cl3Kener/UBER-M Cl3kener is a good dev, so you can look at this
Wysłane z mojego Nexus 5 przy użyciu Tapatalka
