Ok, disregard the crazy high benchmark scores...seems the change that allows for those breaks some stuff, but Ill keep working on it. Next kernel will be significantly smoother regardless.
mikaole -
24. Oktober 2015 um 09:17 -
V5.2 in testing now ..... its very smooth like I expect from V. Not sure how you guys didnt complain It was choppy before. Its much better now and battery is quiet amazing. I get 4.5-5.5 SOT every cycle now.
5.2 online.
Kann man ihn mal anschreiben, das er seine Gapps mit reinstellen soll?
We want your gapps back:)
Too much work right now especially for something that doesnt improve anything
12/10 Open Gapps seem to be working fine again
Welche nimmt man den da?
In using the full with a custom include/removal script. But to each their own....depends on what apps you use and need.
Have been Running flawlessly 5.2 for a few hours... waiting for 6.0.1... Velocity is finally becoming that great rom that was on nexus 5... It only needs time... And I think this time is over...
Inviato dal mio Nexus 6 utilizzando Tapatalk
Much easier to develop for a device I own. This is why I wont blind build anymore.
After about 36 hours I may say that this ROM is almost perfect... Almost because it would be fantastic to have a specific "velocity" menu in the main settings page with all the customisations... Each other thing in this ROM is perfect... Battery life is also very very good... Mvk is certainly the best kernel around... Great job...Nach etwa 36 Stunden kann ich sagen, dass dieses ROM ist fast perfekt ... Fast, weil es wäre fantastisch, um einen bestimmten Menüpunkt "Velocity" im Haupteinstellungsseite mit allen Anpassungen haben ... Jede andere Sache, in diesem ROM ist perfekt ... Die Batterielaufzeit ist auch sehr sehr gut ... Mvk ist sicherlich die beste Kernel around ... Great job ...
Sorry me for my bad Deutsch
Then it will never be "perfect" in your eyes. Velocity will never have a separate menu like everyone else does. Im not into copying other Roms and like to keep the look as close to stock as possible.
Oh what the fool
sorry... Don't misunderstand me... Your ROM is the best of the best... I have been loved it since I was on hammerhead... Sorry again... Velocity is perfect yet...Inviato dal mio Nexus 6 utilizzando Tapatalk
V6.0 in final testing .... this is a much smoother/faster build than 5.2. Im hoping to have it for you guys in the next 24 hours.
Much smoother than 5.2?is it possible? so aliens helped youInviato dal mio Nexus 6 utilizzando Tapatalk
Very nice! Can't wait to try it :eek: -
V 6.0 out!!!!!!
Clean flash empfohlen
Sollte unter xen shamu usern jemand dabei sein bei dem das Phone automatisch verschlüsselt ist, dann gibt es hier die Lösung. Sollte dann auch bei anderen roms so sein. Zu sehen unter Einstellungen, Sicherheit unter Verschlüsselung. Steht da Telefon verschlüsseln ist alles gut. Ansonsten
