![](https://smarthome-treff.de/images/avatars/55/119-55f76e01e75364ec62d0663a480f51cfbdeba295.jpg)
mikaole -
24. Oktober 2015 um 09:17 -
Great rom! Is there any issues with the tracker? It says the file doesnt exist.
No tracker anymore
Oh why is that? Sorry for asking
Because there will only be more and more speed optimizations.
All features are included, so no use for a tracker. -
Because I dont have time to maintain one and most everything I put on there anyway know one understands.
SwiftKey issue is gone with the update from yesterday. A short question: when ditty flashing, should I do wipe system, dalvic, cache and reflash ROM, gapps or just wipe cache, dalvic and flash ROM? Thanks in advance! Also thanks for the daily Dosis of ROM to satisfy my flashoholic needs.
i always flash rom/gapps and wipe system/dalvic and cache.
Thanks, that's what I do usually but when I did that with Pure Nexus ROM I ended up with force closings all over the place.
sometimes a clean wipe is necessary (wipe data/system/cache/dalvik), but this can tell you the dev only.
Dirty flash is wiping nothing. But I typically wipe system, cache, and dalvik when Im not going to clean flash.
Is this compatible with Layers and Xposed ?
All marshmallow roms are layers compatible and xposed is for stock roms not for custom romz
Running 6/2 build... Flawless... I have been using it for 7 days... Velocity is the best
Inviato dal mio Nexus 6 utilizzando Tapatalk
