https://www.android-port.de/index.php?threads/5076/
Einmal durch lesen bitte speziell 1. und 2. Post
Heute nur mal copy and paste, ich hoffe ihr verzeiht mir ![]()
01/09 PureNexus HammerHead update based on 6.0.1_r10 January security update is Live!!
Download link: ungültiger Link
PureNexus Dynamic Gapps Download: ungültiger Link
01/09 Release
Update: updated aosp source to 6.0.1_r10
Update: updated exfat source to v1.2.3
Update: updated nexus player kernel source
Update: updated nexus 6P kernel source
Update: updated proprietary binaries for all devices
Update: Various bug fixes and stability improvements see github
Change: now using prebuilt kernel for flounder(Nexus 9)
Change: enabled ccache on art & skia 10 min drop in build times
Change: Prebuilt exchange services is now shipped with the rom (most gapps dont include)
Change: Prebuilt Smart Device Setup is now shipped with the rom (most gapps dont include)
Change: Moved the “More” notifications icon back to the left like it was on stock
Feature: add option to select font style for the lockscreen clock
Feature: add ability to use battery led on Nexus 5X and fixed liblights
Fix: issue where adb sideload would be stuck at 47% while sideloading roms via adb
Fix: issues where some devices would have install errors (n5/n7)
Fix: issues where long pressing brightness tile would show brightness slider behind quicksettings
Fix: adoptable storage now works on Android TV devices, probably all devices but have not tested
Wer Layers nutzt sollte Spectrum mal probieren, dort sind auch die PureNexus- Settings gethemt
https://www.android-port.de/index.php?threads/6628/
Update 29.01.16
Linux-Kernel
Es gibt jetzt auch nen build mit der CM Theme Engine is vielleicht mal wat für dat @MuggelPu ![]()
Hier noch der Changelog
1/29-1/30 Release
CMTE-Branch: initial bringup of mm-cmte branch for all devices
Nexus 7 LTE: initial bringup for deb aka n7 lte
Nexus 5: enabled ambient display
Change: cleanup of proprietary files for flo/deb
Change: cleanup of Lockscreen font mod now has all correct fonts
Change: made network traffic meter fonts a tad smaller
Change: long press torch tile now opens camera
Change: screen recordings now get put in screenrecord folder
Change: added a timer to the screen recorder
Feature: add option to disable fingerprint authentication vibration
Feature: add option to enable long press power while screen is off for torch
Feature: add option to disable quick settings on secure lockscreen
Feature: add option for immersive recents stock, fullscreen, statusbar only, navbar only
Feature: add option for proximity speakerphone
Feature: add option to disable network traffic indicator arrows
Feature: add option to disable heads up notifications globally
Feature: add option to ignore interruptions while media is playing
Feature: add option to lower the amount of notifications an app can make in a certain time period
Fix: whitepages people and reverse lookup
Fix: issue where lockscreen weather looks out of place with long weather conditions
Fix: random array index out of bounds error that would sporadically result in a systemui force close
Fix: drawing a vertical scrollbar when fast scrollbar is not enabled
Fix: npe in choosing type and account activity
Fix: npe in text utils
Fix: bluetooth related race condition
Fix: race condition related to notification panel expansion handling
Fix: issue where heads up peeking settings would reset upon reboot
Fix: issue where default clock font was not actually default
Fix: finish circle battery animation upon unplugging device
Removed: fullscreen recents in place of immersive recents
Removed: a ton of outdated drawables from ics/jb/kk that are no longer in use
Auf des CMTE Build warte ich schon ganz sehnsüchtig... Sobald rom online is wird natürlich getestet... N9 leider noch nix da.
Soll heut oder morgen aber kommen ![]()
OP ist aktualisiert, es sind beide Version (Layer und CMTE) verlinkt
[size=24][COLOR=#ff0000]Update![/COLOR][/SIZE]
ZitatAlles anzeigen02/03 Release
Update: aosp source code to 6.0.1_r13 for February security update
Update: proprietary binaries for all devices
Update: google webview for arm/arm64/x86
Feature: added toggle for ambient display notification inversion
Feature: allow google or aosp dialer, no more editing apks every release
Fix: issue where ongoing lockscreen notifications were off by default
Fix: issue where ime switcher was overlapping navbar items
Fix: added missing vendor symlink for nexus 9 “Flounder”
LayersVersion
CMTEVersion
CMTEVersion
So bin wieder auf Layers
Es kommt demnächst wieder ein Update ![]()
ZitatAlles anzeigen02/18 Release
Both Branches:
Change: exposed hardcoded colors in cell broadcast receiver for themers
Change: exposed hardcoded colors in exact calculator for themers
Change: exposed hardcoded colors in dialer for themers
Change: move lock screen owner info text above lockscreen weather
Change: cleaned up and organized pure nexus settings lockscreen fragment
Change: telephony builds now ship with aosp messaging application
Change: Reverted back to system ui quicksettings so broadcast tile works again
Change: updated all rom logos,icons,banners thanks to alex cruz!!
Feature: added option for statusbar notification counter
Feature: added option to hide lockscreen clock
Feature: added option to hide lockscreen date
Feature: added option to hide lockscreen alarm text
Feature: added option to allow lockscreen rotation
Feature: added option for time aware contextual notification header images
Feature: added option to use poly HD images for contextual images
Feature: added option for smart quick settings pulldown
Feature: added call/message blocking
Feature: allow wifi and bluetooth tiles to now scroll
Feature: added option to set 3/4/5 tiles per row in quick settings instead of ¾
Feature: added new tiles usb tether, play/pause, reboot/recovery, ime, heads up, sound
Feature: added option to configure battery light color for 100% full
Feature: added option to configure the long press back kill app delay
Feature: added option for slim recents and slim recent options
Fix: size and spacing of the status bar silent icon
Fix: issue on some devices where ram dumps were continuously ongoing killing battery
Fix: issue where whitepages lookup would force close the dialer
Fix: issue where dialer would keep asking for permission even though it was granted
Fix: issue where the phone icon disappears in bluetooth settings
Fix: issue where backgrounds on expanded statusbar header were overlappingFix: issue with copy/paste in documentsui
Fix: action mode handling in non standalone mode in documents ui
Fix: janky heads up animation
Fix: issue where disabling heads up didn't actually disable heads upCMTE Branch:
Feature: added theme tile ability to change theme or per app theme
Fix: issue where toggling vibrate or bluetooth resulted in a systemui fc
Fix: issue where print spooler would force close when printing
Fix: issue where setting a themes bootanimation didn't work after reboot
Da ist es auch schon ![]()
Layers- Version
bbedward
CMTE- Version
bbedward
ZitatAlles anzeigen03/08 PureNexus Hammerhead Update is Live!!
Layers Build Download link: ungültiger Link
CMTE Build Download link: ungültiger LinkUpdated Gapps Download: ungültiger Link
As always if you like my work dont forget to hit that thanks button.
Donations are always appreciated but never required, I am only posting the link for convenience, Donate linkDont forget to check the changelog Changelog!!
Dont forget to also check the FAQ By @<a href="Donate link" target="_blank">nathanchance</a>: Donate link
This release adds a ton of new features and fixs Enjoy if you have had any issues with previous builds it is recomended to clean flash!!!
Sorry about loosing track in the thread if anything important is needed and i havent responded here please ping me on G+
03/08 Release
Both Branches:
Feature: added full caf based app ops
Feature: add option to allow for increasing ringtone
Feature: add option to configure settings dashboard columns (1,2,3)
Feature: add option to configure settings dashboard text single or double lines
Feature: add option to configure if settings dashboard dividers are present
Feature: add option to show pure nexus logo in the statusbar
Feature: add option to allow vibration on quick settings tiles
Feature: add option to set the alpha of lockscreen and lockscreen bouncer
Feature: add option to bypass the lockscreen bouncer aka unlock straight to pin entry
Feature: display headset icons when headset/headphones are plugged in
Feature: add option to disable the headset icon to statusbar items
Feature: add option to disable the silent/vibrate icons to statusbar items
Feature: add option to disable the vpn icon to statusbar items
Feature: add always option to quick pulldown
Feature: added PureNexus ambient display modifications
Fix: issue with contextual header images turning on by default
Fix: issue where clicking the x in the bluetooth tile detail menu wouldn't disconnect
Fix: issue where the wrong client was used for cut in documentsui
Change: removed duplicate screen rotation option from accessibility
Change: added new pure nexus logo to settings
Change: move ambient display inversion to settings/display/ambient
Update: supersu to current stable 2.65
Update: to latest aosp source 6.0.1_r17
Update: all proprietary binaries for all devices
Update: kernel source for all devices
CMTE Branch:
Fix: keep overflow menu icon consistent in theme chooser app
Fix: the problems with runtime overlay (should make themes more stable)
Fix: compilation issue for theme unit tests
So Opener und Changelog-Post sind up-to-date ![]()
Update :
03/15 Release
Both Branches:
Feature: added flip to mute/reject call
Feature: add option to disable fullscreen keyboard
Fix: issue with password manager apps not working
Fix: issue with supersu not showing up on dirty flash
Fix: issue where app ops title text wasn't visible on first menu
Fix: dvorak keyboard issues should be up to date now
Change: revert aosp messaging back to google messenger
Update: to latest aosp source 6.0.1_r22
Update: proprietary binaries for 5x/6p
Update: kernel source for 5x/6p
Update: SuperSU to 2.68
Downloads:
Layer
CMTE
Quelle
Hier gibt es Test-Builds mit Android N
ZitatTest Builds of purenexus for nexus 6p/5x/6/5 based off the android N preview still very WIP but better than nothing
ungültiger Link
https://plus.google.com/+NathanBenis/posts/Xj2ydsvd7oU
Gesendet von meinem Nexus 5 mit Tapatalk[/Quote]
[/QUOTE]
Kein April-Scherz? ![]()
