[Blockierte Grafik: https://img.xda-cdn.com/38zuf9Mx_FqLvq…WMoeXoh.png%3F1]
The Pure Nexus Project
Disclaimer:
We are not responsible for anything that may happen to your phone as a result of installing custom roms and/or kernels. you do so at your own risk and take the responsibility upon yourself.
"This is a user friendly thread. All feature requests will be heard and considered. I am not against anything that doesn't stray too far away from the original idea of the ROM! Helping one another is also encouraged! Please be respectful and you will always be treated the same way, we are all here for a good experience."
About:
The Pure Nexus Project aims to bring stability and features to your Nexus device, while keeping Google's vision in line and not straying too far away from that. If you are looking for a stable ROM with true tested features and minimal bugs, then this is the place to be.
Features:
Code:
-General
*All stock Nexus features working!!(WiFi calling, Project Fi, VoLte)
*Based on AOSP Android 7.1.1_r21
*Busybox, Init.d, Addon.d support
*Googles Pixel sounds from the factory images not the horrible AOSP ones
*Googles OEM wallpapers from factory images
*Googles Pixel theme and Pixel navbar animation
*Google assistant
*Bug fix's and stability improvements
*UI Improvements (fixed a bunch google forgot to materialize)
*Full Substratum OMS Theme Engine support
*ADB enhancements (ADB over wifi, Hide ADB icon, colored logcat "abd logcat -C")
*Enabled Developer settings by default
*Enabled Night mode for all devices
*Custom night light brightness options
*Disabled forced encryption
*Disabled tether provision checks
*Made preselectable item clickable in app picker dialog
*Added download speed in notification
*Added Advanced Reboot menu
*Added Advanced screenshot functionality (longpress tile/power menu for selectable screenshot)
*Added back volume adjust sounds and toggle
*Added advanced Rotation control and lockscreen rotation toggle
*Added ability to lock app in landscape via rotation tile
*Added Advanced charging sound controls
*Added Advanced seekbar style animation controls
*Added PureAmbient display options
*Added Special keys to all keyboard keys
*Added Quick setting header Longpress actions
*Added ability to see app version when sideloading app
*Added app package name to app info screen
*Added ability to launch app when touching app icon in app info screen
*Added phone info shortcut to about phone/status on top
*Added dynamic vendor image notification
*Added additional battery saver trigger steps
*Added ability to unlink notification volume from ringer volume
*Added Increasing ringtone option
*Added Dialer Lookup, Proximity speakerphone, Incall vibration options
*Removed googles SystemUpdate option
*Removed googles legal information
-PureNexus Settings
Lock Screen
*Lockscreen item option(time, date, alarm text toggles & Clock font style)
*double tap anywhere to sleep
*Long press power for torch
*Option to disable lockscreen media art
*Option to scramble the pin entry layout
*Option to disable the pin ripple background when entering lockscren pin
*Option to disable fingerprint success vibration
Notification Drawer
*quick settings pulldown (left,right,always)
*smart pulldown (no ongoing, no dismissable, no notifications)
*Force Expanded Notifications
*Brightness slider on/off toggle
*Haptic feedback on quick setting on/off toggle
*ability to change quick settings columns (3/4/5)
*ability to change the amount of rows in quick settings
*ability to disable the quick settings title text
*ability to disable quick settings on secure lockscreen
*ability to enable bluetooth,data,wifi easy toggle
*ability to set contexual or custom header images
Recent apps
*immersive recents
*kill all fab
*kill all fab location
Statusbar
*Battery customization(percentage/icon style)
*sync battery icon with quick settings tile
*Carrier Label customization(placement, text)
*Clock customization(show clock, show seconds, alignment, ampm, date, date style, date position, date format)
*Network traffic meter options(enable, display units, update interval, hide arrows, inactivity threshold)
*Statusbar icon blacklist
*Battery percentage/icon options
*Battery bar options
*Double tap on statusbar to sleep
*Status bar brightness control
*Status bar notification count
*Status bar bluetooth battery meter toggle
Navigation Bar
*Navbar toggle and Height/width options
*Navigation bar tuner
*Pixel navbar animation toggle
*Ability to enable one handed mode
*Ability to enabe double tap to sleep
*longpress back to kill
*configurable longpress back to kill timeout
PowerMenu
*Option to disable on secure lock
*Add/remove (reboot, screenshot, screen-record, torch, airplane mode, user switcher,settings shortcut, search, voice search, lock now, sound panel)
Volume Rocker
*Volume keys control media volume
*Volume key wake
*Volume key music control
*Volume key orientation swap
*Volume down to enter do not disturb
*Volume up to exit do not disturb
*Do not disturb volume panel switch
*Volume key keyboard cursor control
*Volume up and power action (screen record/selectable screenshot)
*Volume steps customization
Display
*3 finger swipe for screenshot toggle
*expanded desktop options
*option to enable/disable wake on plug
*Battery and Notification LED controls
Media & Notifications
*Ability to turn off camera shutter sound
*Ability to turn off vibration when double tapping power button for camera
*Power notification controls
*Peeking notification option(on/off, timeout, snooze length)
*low battery notification toggle
Miscellaneous
*force enable or disable scrolling cache
*ability to enable app icon on toast
*incall vibration options
Downloads & Changelog:
Changelog: NYCHitman1
Current Release Download Link: https://forum.xda-developers.com/sho...postcount=8614
Rom Builds: NYCHitman1
Highly Suggested Gapps - Dynamic Gapps: NYCHitman1
Vendor Images(flashable by twrp image option): NYCHitman1
Credits & Thanks:
The Cheeky Bastards - Bajasur, Dwitherell, DaveyAnnihalation, Surge1223!!!
The PureNexus Moderators - MicMars, Kris Nelson, Nathan Chance
The PureNexus Beta and Themer groups
The CyanogenMod Community
Dirty Unicorns
SlimRoms
OmniRom
Euphoria-OS
And all other open source Devs/Teams i may have missed!
XDA:DevDB Information
[ROM][5X][7.1.1_r21]★ Pure Nexus ★ Substratum | Fi | WiFi Calling ★[02/15/17], ROM for the LG Nexus 5X
Contributors
BeansTown106, dwitherell
Source Code: https://github.com/PureNexusProject
ROM OS Version: 7.x Nougat
ROM Kernel: Linux 3.10.x
Based On: AOSP
Version Information
Status: Stable
Stable Release Date: 2017-02-15
Created 2015-11-09
Last Updated 2017-02-15
Quelle:xda-developers.com/
