I use KA to UV and for changing to benchmark settings. I still benchmark almost every build to be sure no regression happened.
Rom Android Open Master OMP Shamu 7.0 N
Unfortunately SMS is again not working on the last two OMP Builds [emoji32]
Interesting as I havent changed anything.
I've clean flashed OMP again and now sms works.
Maybe restoring via backup makes this issue [emoji6] -
Most likely....so youre saying the last build is fine then? And what were you restoring via TiBu?
Tibu : apps + data. I've flashed 13.08.,build. And yes. That's all fine
Unless youre specifically restoring contacts and contacts data there shouldnt be any issue. If you are restoring either of those, I'd stop. Restoring any system apps can cause issues with Tibu.
Only user apps. No system apps, no contacts
Well, Im glad clean flashing it fixed it.
Test build.....
https://drive.google.com/file/d/0BzX_bR…iew?usp=sharing
Test build for the sms problem or just updating stuff? -
Was just to test SMS issue.
OK. Thanks.
Has been a slow coding weekend in AOSP. Im sure it will pick up again today. When there are changes worth building for Ill release a new one.
Hello! I can not get to boot omp HOWEVER velocity boots fine. I am enjoying Velocity very much and I thank you. I can get omp to boot if I place 3 files from Velocity into omp and then rezip. Missing from omp in the meta-inf folder are: CERT.RSA and CERT.SF and MANIFEST.SF
Works fine. I have flashed multiple OMP builds every day for months.
Chad, did you see problems with restoring WhatsApp backup? On my side I can't restore it. And I know another guy with the same problem
I'm sure....its master. I dont use WA so its no bother for me.
Thx. I can still live with that
