Congratulations. You made it [emoji106]
Rom Android Open Master OMP Shamu 7.0 N
Lol ... Those are what I like, not what I own or will likely ever own. I'm just a working class stiff.
Sure. I understood [emoji4]
Sometimes I get FC of system ui when I'm performing a soft reboot. But atm I can't say what is causing that...
Building from master branch is whats causing it. Ive done very little to these builds....this is why no one builds master.
..and know I know what youn meant: "not a Bentley...a Porsche Spider 918"
If you find dass die previous build didnt do that I can take a look, but beyond that it is what it is.
Could be caused by the Longpress on screen off tile in qs?
But when I'm right it was still in the previous builds
Again, if soft Reboot on the previous build doesnt do that, then maybe. How it gets triggered shouldnt matter though.
Problems when installing apps with the Paket installer smarthome-treff.de/attachment/31303/
Yep...you will likely find lots of odd issues. I wouldnt waste my time documenting them all.
Just wanted to let you know
Dont bother .... not likely anything I can do about it. There are literally hundreds of thousands of newer commits in master than in the release branch. If its broken and I didnt break it its going to stay broken until its fixed from source.
Same thing again... ROM is the fastest one I've ever tried but I can't send/receive any SMS ... Have you got some ideas?? Sorry if I'm breaking your bal*s guys...
Inviato dal mio Nexus 6 utilizzando Tapatalk
Problem is SMS is working for all others.
Maybe it has something to do with carrier.
Which carrier are you onon. -
I'm on Vodafoneit... I tried flashing another radio version,tried copying apn settings from velocity,but the problem still remains...
Rom is fantastic...Inviato dal mio Nexus 6 utilizzando Tapatalk
Ok there is one other with the same problem now.
So chad has to look into this -
Nothing to look into....if the initial build did the same thing I didnt break it. I have no idea what would cause that. If you must have SMS you'll have to use a different Rom
Oh... Allright... Thanks Chad!!! I'm right here to test
