Weird, have another user with the exact same and he's running this just fine. 2 more follow up questions.....
Are you encrypted currently? Are you using a "pin" during boot process?
not encrypted and no pin during boot
Hmmm, very very strange then. No one is doing anything special. I assume youve tried this with just the Rom?
Just the rom, so no gapps and no supersu is giving the same result (not booting)
Yea...that one for sure wasnt booting....missed some binaries. New one up shortly. Im also including the vendor.img that builds with the Rom. Maybe try flashing that as well.
Ok thanks, I'll try.... what do we do without you?? ![]()
Installing now...rom, open pico gapps, supersu,vendor file...
Not booting...installing only rom and vendor now...
I think you're going to be out of luck. I dont know what else to try and there is no reason one device should work and another not.
Ok thanks for all! But is there a Nexus 5x version that is omp running?
All of them work fine for those that it works for.
Ok @btb.....I have one more thing Im going to try and them Im going to move on from Bullhead if it doesnt work. Seems like no ones experience is that great with this regardless if it boots or not. This is why blind building is so difficult. I'll have a test up in an hour or so.
Thanks Chad!
https://drive.google.com/file/d/0BzX_bR…iew?usp=sharing
Any luck with this?
Sorry Chad, it's not booting. With or without gapps. Downloaded it twice. No OMP for me... (Restored Nandroid backup with Chroma)
Bummer...maybe this will get sorted at some point.
Can you humor me and try flashing this with a different kernel? I know Elemental works.
I'll try with OMP, Opengapps pico, supersu v2,76 and elementalX 1.17!
Not booting....
Trying with OMP and only elementalX 1.15...
You tried without flashing another kernel?
Don't know if Elemental even works on omp.
Just flashed my friends bullhead and all fine.
A certain % of users on all devices are having no boot issues. Its really weird and I cant see any pattern.
Chad asked to try with elemental kernel.. I'm getting dizzy looking at the turning OMP logo hahahaha.
Still not booting, am I doing something wrong?
