Alright all....long silence is over. Been working on fixing TiBu restore and getting Velocity Marlin working. Back to business now. New build......
Completely redone from fresh 7.1.1 source. All the same features from previous build as well as a couple other minor changes (T9 dialer, more Substratum stuff, download speed + pause/resume, etc). All optimizations are redone. More features and more speed coming soon....I would definitely clean flash this. Enjoy......
Thank you. Everything is working as it should. Fantastic speed!
Great build. Thanks a bunch, @ctfrommn
Thanks, still ok to use open gapps nano?
I think it's OK. I'm using Micro without any problems
Thanks, then i use the micro gapps
Changelog im Opener hinzugefügt
New build....see changelog.
Running great as usual. Top nodge!
One question: is there any option to turn off Pixel animation on home button? I'm using a substratum navbar theme and it looks kinda funny.
Not currently, no. Its coming at some point though.
New build, see changelog, back on AFH again. Enjoy.
New release in the works....see changelog for extensive changes. I will build and test for any issues first, but I would expect one later today.
Uploading now
You know what time it is....see changelog and enjoy.
Yeah. Thanks again for your genius rom
Got a question: I noticed that when i try to change the wallpaper the pixel launcher force closes. Changing it through long press screen and then select wallpaper, the launcher then closes. No idea if that is just me or if its the rom. I am using open gapps micro, supersu and a clean install
Yes. I can reproduce this. Unfortunately I'm using Nova Launcher so I didn't recognize that before.
Formerly there was something like"background" in Settings/Display.
But this isn't there right now. Maybe sorting out this causes the FC.So: Using Nova or other launcher solves the problem for now.
I am using nova launcher as well, but i noticed it when i tried changing the wallpaper in the pixel launcher during the run i gave pixel launcher. I froze both launchers that came with the rom and went back to using nova launcher, no problem with changing background. For the rest..super rom..thank you for sharing.
Do you have the wallpapers app installed? If not, that's why.
What wallpaper app?
