Ok, cool. Is that a stock build or something?
yeah latest beta directly from op. not a beta based custom rom
Does stock OP kernel source encompass both the 3 and 3T? If so, youre welcome to try it.
My Nexus 6 is still running strong, got it since Oct 2015. I can renew my contract in 2 weeks, but as it runs till oct 30 i wait a little bit before renewing.
If i would have to choose one then i would go for the OnePlus5 -
I dont think that this is the case. What rom version is it based on?
Edit: If you decide to make a test kernel for OP3 based on that 3t kernel I would be happy to try it -
Its just built from the newest OSS kernel source. 4.1.6 And there isnt separate kernel source for the 3 and 3T so Im not sure what would make it device specific. On the Rom side there are differences.
...OP5 would be my favourite too.
But my shamu is still running great :-o
Just installed the kernel. It booted up fine. I will infrom you if there is any issues? Do youind telling me any special features of this kernel?
Typical MVK stuff.... KCAL, sound options, Fsync, fast charge, wakelock blocker, my normal defaults (Interactive/CFQ) and likely other things Im not thinking of. Its highly optimized like everything I do. Custom toolchain built as well.
oneplus released kernel sources for betas too now. would be great if you could sync that
Already synced. Very very small difference from release source though. Heres the updated kernel.....
Shamu is back up and running better than ever. I'll hopefully have a release for you guys this week.
Ran into a bunch of issues with other devices but all is resolved now. Look for a release for all in the next day or so. Final testing in progress.
Ok, finally uploading....clean flash HIGHLY recommended.
Newest build is pretty cool. Amazing speed and everything is working as it should.
Great work Chad
Newest Build running great for me too! Thanks you!
There is one thing I need to ask for it's the battery color commits as I use substratum themes that color all icons on status bar even clock and battery but this rom doesn't have the needed commits to have the battery the accent color too. If you could add that I know other roms as DU and Aex have added them and the commits are stable ... Other than that this Rom is unbeatable in speed and optimization! It is running like clockwork!
Get me the commit(s) and Ill happily add them.
Here you go here is the 2 commits I could find ...
https://github.com/ScrewdAOSP/fra…df099c48401decd
https://github.com/ScrewdAOSP/pac…6e33c8440ce4099
Thanks you for the chance!
Thanks for all the work too! -
Those are total custom commits. Something like that wont work.
Ok well I don't know then you have to manually expose the resources for the battery icons then or whatever it is they did for that Rom.
I tried other than that idk -
