  • if you load up magisk for your root solution ... go into magisk manager and click on the tap to start safteynet checkbutton. The check fails. There is a single commit for the kernel that bypasses its bootloader. If yes then it is probably something in the gaps I would think.
    Safteynet here in the USA is used for many things like android pay certain games and netflix. If it fails as it is currently you cannot use the apps or services associated with it
    2 Mal editiert, zuletzt von adm1jtg (4. Oktober 2017 um 19:48)
  • sorry for the above for some reason it wont let me edit I meant that if safteynet fails as it currently does now, that users will be unable to use the apps and services that require that is passes to run/work
  • I already added the kernel. No idea on the CTS one. Afaik Velocity has never passed that. I've never had a chance to do it.
    A FYI, Im in the US. I post here because Im friends with the host. That, and XDA is a complete mess that Ill never post on again.
  • gotcha, cts failure i think is gapps related, but I am no dev. the old beansgapps was the first set of gapps to pass safteynet and i think the opengapps now also pass. I will try some tests and see if i can force some combination to pass and if i can I will let ya know what I did. No matter the outcome I will be staying on this rom its the best I have had on my shamu.
  • Ok ran a few tests and am stumped as to what is needed....
    I tried running a full set of separate gapps
    I flashed the kernel from another rom that passed safteynet over yours
    Both tests still fail safteynet
    So if it isn't kernel related or gapps related I have no idea what it is or where to look.
    I may poke around in the old purenexus github as at one point he did some things to make it pass when it hadn't previously but again i am stumped
    That said GREAT work and will be staying on velocity no matter what.
    Is longpress back button to kill app on your list for next build by chance?
  • Are there any current Roms (with a git) that pass safetynet? I dont know if Ive seen long press to kill yet on O. I'll look though. All features I had on N are things I would be open to adding back.
    Do you happen to have a telegram group? If you need anyone to test anything I would be willing to help. Thanks again.
    Whats a telegram group? If youre interested in testing prerelease builds thats always welcome. I'll PM you with my hangouts email.
    Here are the 2 commits needed for safety net to pass...
    This one first
    https://github.com/sultanxda/andr…fd4680c5ed37e73
    Then this one
    They should merge clean
    Let me know if you have any conflicts or such... Also I would be willing to test pre release build for you too. As I k ow your prereleases are more stable then most stable roms lol.
    Hope those commits help you out.
  • Im getting very close to a release build. Just need to do some last minute cleanup and testing but expect a build today. This will be clean flash ONLY. GApps are also no longer included but I will link a working Open GApps zip as well. Unmodified open gapps do not flash properly. There are other gapps out there you can use as well. There is no gapps backup script yet (still not working properly) or root solution built in so make sure you flash Magisk/SuperSU. This is radically different from the last build so see changelog for full details.
    Edit: Open Gapps now install properly as is so pick your pack and flash like normal.
    Einmal editiert, zuletzt von ctfrommn (13. Oktober 2017 um 20:29)
