This is a 8.1 oreo, based on dp2 https://androidfilehost.com/?fid=889964283620769672 .Also, check this https://plus.google.com/communities/111402352496339801246
There was no source for 8.1 prior to yesterday so not sure what that is. Definitely not a source built Rom. Good to see someone got 8.1 to boot on Shamu though regardless.
Final 8.0 build is up. See changelog for details. This was basically a complete redo of everything. This should run much better all around as well as improve battery life and stability. I will start work on 8.1 in the next day or two.
8.1 isnt going to be a simple ordeal. This will be starting completely fresh again unfortunately. I'll keep you updated as builds come out.
So, 8.1 does boot on Shamu and things seems to work. Need to see about getting Gapps working but it looks like it will be possible to port this again.
everything seems to work so far though I havent tested all of it
wifi, data, location, BT, and sensors all workand camera
no NFC again though
Sounds/audio don't work and not sure why so no builds until someone sorts it out.
Thanks for new build
Try this ...:)
https://github.com/camcory/device_moto_shamu -
So, as you grabbed this from XDA thread, ctfrommn has it already
I have grabbed this with no intention to offend anyone. I have read the problem and I have grabbed this for give a little bit of "help", since I don't a developer! -
Yeah. That was my intention too;)
Hopefully he will get things right.
I hope so too -
Sounds issue is resolved. BT and NFC arent really working as intended though. I'll sort all of this out, it will just take time. And thanks to both for the link. I know about Camcory's source.
Amazing! Take a look at this source of new 8.1 Nephilim ROM by Frankie T (R3DS)! It should all work :jaded:
https://github.com/NephilimRenown -
Have you flashed the Rom?
I'm going to flash now -
I have tried it and it running smooth and fast with all functions (?), but I don't like heavy customisation and I'm back in your ROM!
However, Cypher OS too has update the ROM on 8.1 but only NFC doesn't work!
https://github.com/CypherOS -
I have everything working apart from NFC (which I dont think works on any 8.1 Rom) and Hotspot now. Much much more to do, but I think this is daily drivable now. Let me know if any of you want to try these builds and Ill link them here.
Amazing! I'm ready for try It! -
GBoard
