Sorry for my bad english:speechless:
How to restore this
https://drive.google.com/file/d/1vsMi5M…ew?usp=drivesdk
With this?
https://drive.google.com/file/d/1lUyxL4…ew?usp=drivesdk
Pretty sure most android 8.1 roms have the brightness bar at the bottom now. If you want it at the top maybe flash a 8.0 roms they have it that way.
Personally i like it at the bottom of the qs tiles. It is much more sleek and looks better in my opinion.
Yes, it's on the bottom now. If I can figure out a way to make that selectable then you may be able to change it. If not, this is the new normal. I prefer it like this.
Thanks for your patience
I dont use NFC, but guys on xda talking about this rom https://androidfilehost.com/?fid=889964283620771913 and they telling NFC is working.
NFC doesn't work on that build. I just tried it. -
What bout this version
https://androidfilehost.com/?fid=673791459329068274 -
Test it and see
Sir, the 12/19 version is running Super Great as always. You have included the NFC option, not know if it's working or not as I never use it. I had simply turned it. The battery backup is the best and this one's a beauty. To just inform you sir, the Cast option is not working when I enabled wireless display and tried to miracast to my tv. Thank you so much for your rom Sir.
NFC doesnt work on any 8.1 Shamu Rom Ive seen. Not sure what battery backup is, sorry. I dont use and cant test miracast.
hi I have a problem with this ROM, up to Android 8.0 all smooth when I install the 8.1 version openGapps do not install.Ho done I have clean installation, I also deleted the internal memory and nothing.Other rom 8.1 works all this nothing.Thank you. I really like the rom I've been using it since October.Any suggestions?
Not sure what youre trying to say. The GApps pack in my folder install perfectly. I've clean flashed at least 20 times with them. I assume youre flashing the Rom in the test Drive folder linked here and NOT the build on AFH? Thats an 8.0 build and of course wont work with the modified 8.1 GApps.
But where do I need to download? Can you show me the links?
Of course, I've downloaded so far but since it came out 8.1 does not work for me. I also downloaded the last 25 more gapps that are always here, after I install gapps he writes me that he installed well, after the restart the gapps not There are???
I also tried to install gapps from Nephilim rom with last Velocity bild and nothing ???
Im having a very hard time understanding what youre saying. My 8.1 builds and GApps are in the folder I just linked and work perfectly. If youre having issues installing either it is something on your end.
The bild that came out on December 11th went on my phone, after every version I install yes install but gapps no, no I know why?
Ok, Ill take one more attempt at explaining this and then Im done. The 11th build is an 8.0 build, NOT an 8.1 build. ONLY 8.0 GApps will work on that build. The builds in the folder I just linked again are 8.1 builds and there are also 8.1 GApps in there. YOU CANNOT MIX 8.0 builds and 8.1 GApps.
Either continue using the 11th build with 8.0 GApps or CLEAN FLASH the 8.1 build and 8.1 GApps.
Actually, I have no idea what build youre using. I have no 12/11 build. The oldest 8.1 build I have is 12/13 and the last 8.0 build is 12/6. If you want 8.1 just flash the newest build in the folder I linked. CLEAN FLASH ONLY.
Maybe we did not understand each other, I did not mix anything, I installed Velocity 12-25 with gapps 8.1 and gapps did not install?
Then there is something youre doing wrong. I use those GApps for every build and they work fine.
