I tried other ROM 8.1 like Nephilim, Beltz and yes it installs all just Velocity 8.1 gapps are not installed. Too bad I like the rom.
I repeat only 8.1 do not work, if I put the 8.0 of 11 December all smooth.
Well, its definitely just your device. My guess is you have something set differently in TWRP or youre encrypted or something else is going on. Ive clean flashed at least 20 builds since my 1st 8.1 and never have any issues.
I agree with you, but I can not find what's wrong? where is the problem ?. I installed TWRP 3.2.1.0 without touching anything.
And youve tried other GApps? No warnings or errors in TWRP when it installs?
I tried the gapps of Validus tells me error 20, Nephilim gapps yes it installs no error but on reboot there is nothing like on Velocity.
Don't know if this could be the problem. Many users with pixel have problems with newest twrp. Have you tried 3.2.0
3.2.0 no but before I had the 3.0.2.0 I try.
I tried with TWRP 3.0.2.0 with 2.8.5.0 and it did not work.
Im using newest TWRP (3.2.1-0) without issue. My guess is this is something to do with being encrypted or some other stock Rom addition. I havent flashed a stock build on Shamu since I got it. This has to be some sort of permission issue thats keeping it from installing GApps. If you are encrypted, try reflashing stock (or 8.0 build) and then decrypt your data. make sure to back everything up as you will lose all of it.
How should I do the reflash stock and how should I decrypt the data?
Yesterday I installed stock with flashall.bat.
If you want to decrypt, it´s an easy way. Type Decrypt Nexus 6 into google search. First result is a "how to" in another forum
Everything was much simpler, just after each installation restart recovery,rom reboot recovery,gapps reboot recovery,install supersu or magisk.Enjoy.
Thank you all for your help.
Happy New Year.
for the gapps issues has anyone checked the bootloader version? Just for grinz?
I had started all features over last week as I was hitting a wall. Progress was/is going well though I have been ill for the last 5 days. There will be a new test at some point though some of the largest, most difficult features (DUI, etc) havent been added back as of yet. In the long term this will be a much better result though.
New build finally ready. Clean flash only. This was a complete redo of features so some are gone and many more are added. Im definitely not done adding them but this should be the majority so far. This is almost/basically a completely new build. Its noticeably faster than previous as well.
Thanks for new update, btw NFC is fixed on latest Nitrogen and Nephilim roms, just to inform you.
