Be curious to see what fixed it. Nothing on their gits makes it work.
This is changelog from latest nitrogen https://raw.githubusercontent.com/nitin1438/Nitr…12018/Changelog
People reported Nfc works... -
Nevertheless....it doesnt work for me.
I can confirm NFC works on Nitrogen....now to figure out why and get this working.
Update: Well, that didnt take long....NFC sorted for next build which will be up shortly.
New build up....tons of other changes beyond NFC being fixed. I'd say features are about 75% done now.
Is smartbar back in yet? I kinda like it.
Nope and not sure it will be, Its a very complex commit and very hard to add.
Google photo is interrupting, it does not work.
Not sure what that means. Works fine for me. Not really interested in bug reporting either. Im sure Ive said that before.
Not sure what that means.....
Just scrolling images and app crashed, otherwise is working. -
Ill take a look. If its reproducible Ill look into fixing it.
New build up. Photos issue should be fixed as well as various other changes. Couple new features and a bunch of custom settings reorg.
Hello is it possible to put the navigation bar at the bottom like on the google pixel 2 launcher? Thank you.
This is a prebuilt launcher not anything I can modify. There are Pixel2 launchers out there you can install if you want that. I dont like the search on the bottom which is why Im not including the P2 launcher.
OK thanks.
A great job, thank you very much.
I found out now that the camera is not working, you confirm that your work?
All right I restarted a couple of times, and now it works.
Another new build. Bunch more changes, fixes, and additions.
