Man, they let anyone in here Im gonna have to talk to management about getting better security! Hows it going? Very VERY long time.
I will kick him immediately
Welcome
thanks for the welcomes .. things are complex but good .. I flashed the 7/6 8.1 build, very nice - fluid and quick - and that's a suprise for my shamu. I am very glad to have found Velocity again I think the last version I used was a "master (?)" for mako. It was too much for my slow binned mako as I remember. Looking forward to the fun and excitement of a new version of android with you all.:)
Time to get a piece of the pie now
Glad to see Velocity back in action. Hey all! ;D
just saw new shamu's on amazon for 189...https://www.android-port.de/themen/rom-o-8…-42#post-539976 not sure of seller but worth checking out...
Think I sorted out the received call issue as well as the losing cell connection on reboot issue. Have some more testing to do but look for another build in the next day or so.
I am getting ready to flash alpha1 .. wheee...
New build up. Pretty sure the VOLTE issue is resolved (works for me at least) and the network connection on reboot is fixed (for me) as well. This build has a bunch of kernel changes, build optimizations, and fixes added. I would recommend clean flashing again.
WiFi hotspot is still broken. If you have data connection on it doesn't turn on, if data is off it turns on fine. Same behavior as in the first alpha build.
But keep up the good work. You have the best pie rom available, the brightness slider works fine, not broken like in all other pie roms where it doesn't go dim enough.
Is it working on other Roms?
The hotspot? Yup, works on every single one. Tested it already.
You can try to pick/find their commits because they got it working. I believe it's related to the data connection because that's what's not letting it turn on.
Interesting. I havent seen anything related to it from anyone. I have literally never used it on Android so no big deal to me either way. If someone wants to track down a commit cool or if I run across one Ill add it but Im not losing sleep over it.
Sure your rom your priorities
Just was pointing that out because I tested your rom and the hotspot is a feature I use every day on my car. So I noticed it was broken and decided to shout out a warning in case you didn't know.
@ctfrommn
Thank you for sharing "Velocity_shamu_pie_beta.zip" ! -
Thank you Devs for your time and effort with this old whale! Can anyone confirm cast using built-in cast works? Ive tried a few early P builds and for me everything works on most of the ones ive tried except cast.....I had no issues casting showbox movies to my roku smart tv on Oreo, but so far on P, the built-in cast doesnt even see my smart tv when searching....its the only thing Im waiting for for P to DD for me. Thank you all again very much
isdit: I flashed it and when enabling cast, it only sees chromecast devices fwiw -
I am really enjoying Velocity Pie .. I had some problems getting my cellular data to turn on (It has happened before with some oreo roms - I have tello (Sprint))- but got it sorted. Before I was able to fix it, I tried another solution that I had seen mentioned- a dirty flash of pie over an oreo install. I expected a big fail but it worked, ran, and i had cellular date So I knew I could have my ple and data too.. so I did another clean install of Velocity P and got it working. Thanks again Chad, you have saved me $$ by making my phone fast,fluid, and pie-filled and thus not needing to upgrade my N6.
Is this working on other Roms? -
apparently androidx (xda)
I have no non Chromecast devices so I cant test that.
