Updated build... Should be much faster.
https://drive.google.com/file/d/0BzX_bR…ew?usp=drivesdk
ROM] [N] [7.1.1] Velocity bullhead
Thank you Chad!
Thanks Chad ... took the time to register here as well
Round 1 of features....
https://drive.google.com/file/d/0BzX_bR…ew?usp=drivesdk -
Welche Version vom Vendor Image muss man flashen?
Round 2...bunch of new stuff.
Fewer notifications
Safe headset volume
Fullscreen recents
Lockscreen shortcuts- Initial version
Tap to sleep options- Nav, status, and lockscreen
Expanded notifications
Battery bar
Pin scramble
other stuff Im sure Im forgetting -
New build....a TON of new features. Too many to list right now. You'll have to just explore.
https://drive.google.com/file/d/0BzX_bR…iew?usp=sharing -
Thanks Chad, time to see what you bring this time!
Thanks Chad! Have a nice sunday!
Ton of underhood changes......
Next build brings a bunch more stuff....
- Advanced ambient display options
- Quick pulldown (complete version)
- Smart pulldown
- Settings shortcuts for SuperSU, Superuser, Substratum, and Kernel Aduitor
- "Fancy animations" toggle
- Fullscreen recents clock/date option
- Ability to remove dashboard title info and conditions
- Reset battery stats
- Toggle for charging vibration
- Updated kernel
- Other various cleanups, fixes, and optimizations
New build...no new features this time....just some cleanup and updated toolchain/kernel.
Hello Chad,
Thanks for a new Velocity build! But....
Google+ is not working on te last build (2016-10-01). First I did a dirty flash and Google+ closes. After that a clean flash and Google+ still closes.
Do you know why? Can I do something? Am I the only one?Many greetings from a cloudy Holland.
btb, I just flashed it, dirty flash, and my G+ working good.
Not only Google+ closes, but the phone is rebooting after opening Google+
I can confirm that on build 2016-10-01 Google+ is making the phone reboot. (flashed dirty)
Hello I'm here new, Google, Google+ is making the phone reboot. (Clean flash ) gasps open nano ...
Thanks for nice firmware
Which GAPPs did u guys use .... latest opengaaps are having issue ... I suggest using Sept 25th gapps for now. I clean flashed latest build with 9/25 open gapps and no issue. Also if u use any theme, try without them first.
Hope it helps. -
