Dirty flash, gapps 01-10 - Google+ closes.
Clean flash, gapps 01-10 - Google+ closes.
Dirty flash, gapps 25 sept - Google+ closes.
Clean flash, gapps 25 sept - Google+ closes.
Clean flash, gapps 25 sept, ElementalX kernel - Google+ is ok!
Is the Google+ problem maybe kernel related?
ROM] [N] [7.1.1] Velocity bullhead
Hello this news for opengapps
New build time....
- October security update
 - Updated kernel and binaries
 - Omniswitch option for recents
 - Proximity speaker (Automatically changes call to speaker when removed from ear)
 - Reverse dialer lookup
 - BT "easy" toggle (option to make it single click on/off)
 - QS options for number of rows/columns
 - Updated clang version from AOSP master
 - Various other fixes and improvements
New build time....
Thanks very nice upgrade dirty flash all work
Everything is working great, thanks Chad!
Next build adds...
- Full LED support for notifications and battery colors
 - Battery icon options
 - Breathing notifications
 - Updated kernel toolchain/kernel
 - Odds and ends
hello to me after upgrading to Android 7.0 does not notice the LEDs when missed calls (I ADJUSTMENT green very short) Emal, sms, mms is alright.
I feel like with all the new(er) users on here now its time to restate my "bug reporting" policy. If you wish to tell me about something that isnt working AND you want it fixed here is what I need....
A reproducible sequence that causes the stated issue AND (this is the most important part) the exact build it stopped working on. If these 2 things arent provided dont even bother reporting something as I wont read it.
New build time....just spent like 40-50 hours completely redoing the build optimizations on both the Rom and kernel. Each change was tested one at a time to determine what made it faster/lighter/better and those changes were kept. The rest was all scrapped. I hope you enjoy it. Builds will be on AFH again going forward.....link is still in the OP as well.
franciscofranco -
When do you sleep? Zzzzzz
Mad scientists never sleep
Next build will add....
- Disable QS on secure lockscreen
 - Nav bar on/off toggle
 - Pattern lock grid size
 - Quick pin unlock
 - Allow blocking of notifications on secure lockscreen
 - Fix night mode QS tile not always showing
 - Improved expanded desktop QS tile functionality
 - Bunch of fixes and various improvements
 - More speed
 - Updated kernel toolchains/kernels
 - Quick pin unlock
 - More speed
Hi Chad, I'm glad to find around here. I was following you for a while for hangouts when I had a Nexus 5. But problems had to disconnect from all over the world. And now I have a nexus 5x and took time looking at you, and at last I found you. I hope to continue enjoying your wonderful work.:-) -
Androidfilehost say me: OOOPS!! no mirros found
Yep...AFH is looking into his issue. New build will be up soon. Great to see you around still. Welcome.
download new build 15-10. time to test it
Great to see someone off the old hangout group. Welcome
greetings from my new nexus 5x velocity:D -
I'm forgetting the bad battery of nougat stock
Hi. Today had a problem with the last version 16-10. I had charging and when was led green, caught my Nexus 5x, but did not work, screen completely black. Press power button some time and power on. I will try to do a log if repeat the problem.
