Btw changes coming in nextbuilding
looking good ! Thanks Chad
ROM] [N] [7.1.1] Velocity bullhead
Welcome...much more coming also. Next build will be a large update.
New release in the works....see changelog for extensive changes. I will build and test for any issues first, but I would expect one later today.
Nice!!
Uploading now
Up and running nicely!!
Do you still have the velocity boot animation, was a tachometer or speedometer?
Was pretty badasxx
Probably, but that was designed for Lollipop and doesnt really fit with the current Rom theme. I know nothing about making the so unless someone volunteers to update it it will just be a part of the past.
Roger that
Chad, how about multi column settings menu?
Something your are interested in adding?
You know what time it is....see changelog and enjoy.
No idea what that even is or what purpose it would serve. -
Thanks for da update
[QUOTE = "ctfrommn, post: 158653, member: 2957"] [attach] 32444 [/ ATTACH] [attach] 32445 [/ ATTACH] [/ QUOTE]
Haha, you are da man!![/ATTACH]
What up Chad, looking for to it my friend!!
Ok, close to new build time....BIG changes on the optimization side. This build will be built with Velocity custom clang toolchain built from LLVM master branch. This, like the kernel toolchain is and will be updated constantly. As of right now though, DO NOT clean flash this build. It will almost certainly fail to allow you to get past setup. I'm working on a fix, but its something to do with using newer clang and since almost no one else uses this its going to be a challenge to get it fixed. Dirty flashing works perfectly though and shouln't give you any issues. This will be a LOT faster than the previous build and battery life should also be better. I am just finalizing the March security update now then Ill have these tested. I would expect a release tomorrow barring any issues with testing.
Sounds great
Build up... Dirty flash only for now
Awesome! Thanks running Bullhead now, thanks for the columns! Looks so much better. Wanted to post a screenshot but it's not working, not saying it's a bug, could be my settings. Anyways... Awesome!!!!
