New build inbound, clean flash HIGHLY recommended
Rom Velocity Marlin 7.1.1
There will be an error message on startup. Don't worry all fine
Working on that.
Fixed:)
I am really excited to give this ROM a try. Something new for Pixel XL. Is there any gestures included in kernel?
Not new. Been building for this for a while now. Gestures? You mean like wake gestures? No.
[QUOTE = "ctfrommn, post: 158916, member: 2957"] Not new. Been here for a while. Gestures? You mean like wake gestures? No. [/ QUOTE]
I meant new to me and a new build. Yes I meant wake gestures. The internal device warning when booting can be fixed by taking the build finger print line from /system/vendor build.prop and copying that over the build.prop line in /system. They do not match, that's where the error is. One but I noticed is when I select reboot to recovery from reboot menu it does a normal reboot. Thanks! Will run awhile. -
Yea, reboot issue is almost assuredly because of using O-Preview kernel source. Testing that now. Will be a new build to address all this stuff soon.
Update: Has nothing to do with preview source. I have no idea what is causing this. Its existed in basically every build Ive ever made and never noticed. I'm not sure if/when this will be fixed.
New build inbound. See changelog. This build is noticeably faster.
New build inbound. See changelog per usual. Dirty flash is fine.
New build inbound. Big changes this time. Clean flash recommended, especially for the full force of this build. See changelog as usual. This build is significantly faster than previous ones.
