Philz Recovery Update
4.92.3 (03.04.2013)
- properly set time for all recovery session: this will now apply to the time stamp of any file modified (logs, backups...)
- add Daylight Saving Time support
4.91.9 (03.04.2013)
- merge and fix fb2png source: now built as static binary and compatible with RGBX devices (Nexus 4...)
special thanks for this to McKael and a huge thumbs up to talustus for his great support
- silent failure when formatting non existing /sd-ext volume
- use statfs instead of stat in nandroid operations
- misc fixes
- i9100/n7000 zip installer: option to skip flashing superuser using philz_installer.cfg
- i9100/n7000: disable init binary substitution from older LSJ (aka /data corruption bootloop fix)
- i9100/n7000: update clockworkmod superuser to 1.0.1.7 (security fix)
Download v4.92.3:
[DLMURL]http://www.mediafire.com/file/1qdegbuijosv68c/philz_touch_4.92.3-mako.zip[/DLMURL]
