Ich möchte euch mal das Modul GravityBox vorstellen. Mit diesem könnt Ihr, in meinem Fall ausgehend von Stock 4.4.2 unglaublich viel an eurer Rom modifizieren.
Ich möchte jetzt dazu keinen Roman schreiben da es soviel ist was Ihr anpassen könnt. Deshalb lest euch die Featureliste durch und probiert es einfach aus.
Für mich persönlich unter Stock 4.4.2 das beste Modul was man bekommen kann um sein Phone zu individualisieren.
[COLOR=#ff0000]Version für KitKat[/COLOR] findet Ihr hier. ungültiger Link
[COLOR=#00b300]Feature highlight[/COLOR]
GravityBox provides 2 main groups of features:
Fixes - help to fight typical MTK6589 bugs like:
--- Date&Time settings crash
--- Caller ID mismatch
--- Split conversation in messaging
--- Wakelock in calendar app periodically turning on the screen
--- Waelock in messaging app turning on the screen every time new message arrives
--- Missing TTS settings in Language&Input
--- Missing extended developer options
Mods - the set of additional useful features that make using the system more easy and fun
--- CyanogenMod Pie controls
--- Expanded Desktop
--- Statusbar QuickSettings tile management with tile reordering
--- Lockscreen targets
--- Statusbar color and transparency
--- Statusbar Brightness Control
--- Statusbar icon colors
--- Additional QuickSettings tiles:
------- Sync on/off, WiFi AP on/off, GravityBox shortcut, Torch, Network mode (2G/3G/2G+3G switch), Sleep, QuickRecord,
QuickApp, GPS on/off, Ringer mode, Volume tile
--- Quick pulldown - switches to QuickSettings when status bar is pulled down near edges
--- Auto-switch to QuickSettings when there are no notifications
--- Center clock in statusbar
--- Battery indicator style
--- Navigation bar tweaks
--- Low battery warning policy
--- Disable LED flashing when battery low
--- Disable LED while charging
--- Auto-hiding of signal icons for empty SIM Slots
--- Advanced power-off menu (reboot, recovery)
--- Volume key cursor control
--- Skip tracks by volume key long-press while screen off (thanks to rovo89)
--- More volume levels for music stream
--- Option to control safe headset media volume
--- Button for clearing all recent tasks at once
--- Fullscreen caller photo
--- CRT screen off animation
--- Minimal brightness setting
--- Autobrihtness levels adjustment
--- Lockscreen tweaks - show widgets maximized, lockscreen background style (color fill, custom image)
--- Lockscreen rotation
--- Phone tweaks - flip action, disable vibrate on call connect
--- Hardware key actions - menu long-press/double-tap, back long-press, home long-press
--- MasterKey vulnerabilities patched (thanks to @Tungstwenty)
--- Dithered Holo background
--- Option to use solid black Holo background
--- Expandable volume panel
--- Option to unlink ringtone and notifications volumes
--- Notification drawer style (background color, image for portait/landscape, transparency)
--- Button backlight modes (default, disabled, always on while screen is on)
--- Button backlight notifications (for devices that lack Notification LED)
--- Navigation bar ring targets
--- GravityBox Actions (shortcuts)
--- Lockscreen "see through"
--- Smart Radio
--- Notification control (allows controlling notification lights/sounds/vibrations on per-app basis)
... more to come
[COLOR=#00b300]Download / Installation[/COLOR]
Das Modul downloadet Ihr am besten über den xposed installer unter dem Punkt "Downloads" und installiert das Modul.
Startet danach euer Phone neu und Ihr könnt mit dem anpassen beginnen.
Quelle. Tungstwenty
Viel Spass beim anpassen
