Xposed Framework -Zweite Alpha-Version für Android Lollipop veröffentlicht [Update 09.03.2015]
[OFFICIAL] Xposed for Lollipop - NEWS & Download
ZitatAlles anzeigenIt seems that many people have waited for this moment, and here we are:
Xposed for Lollipop is finally here!
You can find a list with Q&A on the XDA Portal. Please read it, you will find many answers there.Note that this is still an alpha version and for Lollipop on ARMv7+ devices only.
Please install it only if you're willing to take the risk of boot loops. Just because it's working fine and stable for me doesn't mean it will work for everyone the same way.Downloads:
xposed-arm-20150213.zip: Must be flashed with a custom recovery to install the framework.
XposedInstaller_3.0-alpha1.apk: Must be installed to manage installed modules
No, it's not using material design yet. Yes, there are more important topics for now.
XposedBridgeApi-20150213.jar: The API for module developers, in case they want to make use of some new features. Might be changed slightly until the stable release!xposed-arm-20150213.zip
XposedBridgeApi-20150213.jar@fraz14
fielmann oder dann diese eben
:wtf:
Gibt es da Einschränkungen aktuell? Müssen die Module auch angepasst werden oder laufen die so. Wäre natürlich ein Hammer
Do we need to rewrite all the modules?
No, the Xposed API is pretty much unchanged. Xposed abstracts all the details, so modules don’t need to care whether they’re running on Dalvik or ART. Many modules will actually work without any changes, especially those which modify the behavior of user apps. Modules targeting the system behavior might need to be adjusted to the new Android framework code, which isn’t caused by ART, but simply by architecture and code changes that happen between any two Android releases. The most significant one is that the code for system services has been moved to a separate file. For most of the affected modules, this can be solved by a little refactoring (moving code to a different place).
Klingt gut. Kann ich ja endlich bald wieder die G3-Tweaksbox verwenden.
ROFL. Du Screengrabber @MuggelPu
[emoji1]
Gemischtes Feedback.
Greenify bekomme ich noch nicht mit den experimentellen Features gestartet.
XGELS geht mal so, mal so. Die Tabs, die ich wie im Screenshot eingerichtet habe, funktionieren mit Animationen 1.0 in den Dev Options gut, sobald man aber runtergeht (zB 0.5) wird es wirr.
Keine Bootloops oder ähnliches, also ein guter Start hehe -
Das würd ich Blind so unterschreiben! Für Anfang ... aber wirklich legga gelungen!
edit:
so schnell kann ich garnet screens machen ... wie die news eintrudeln
deshalb bist und bleibst du MEIN HELD!
Joa, AA for President!
LOL...Intelli3g schaltet wild zwischen WLAN, LTE und 2G hin und her auf meinem Oppo mit LiquidSmooth, aber auf der Mega-Flunder mit Slim-LP funktioniert zumindest Statusbar-Icon-Hider.;)
Hat schon jemand XPrivacy probiert?
Edit in eigener Sache: anscheinend soll es noch nicht gehen.
Shit, da geht man mal früher ins Bett weil einem die Kinder geschlaucht haben und jetzt bin ich der einzige auf ap, der noch kein xposed installiert hat[emoji15] [emoji16] [emoji23]
Geile Geschichte, Jungs.
Ich hab es auch nicht
Ich schon[emoji12]
Muss mich später damit nochmal beschäftigen...kriege es derzeit nicht aktiv
Auf dem G3 soll es wohl noch nicht funktionieren. Habe es aber selbst nicht getestet
Ich habe das ganze beim Nexus 6 auch noch nicht zum laufen bekommen.
Naja warten wir mal ab.
Ist aaber schon mal seeeehr genial das es xposed doch zum Lolli geschafft hat bzw auf gutem Wege dorthin ist. -
BTW ... xposed-arm-20150213b.zip online
Zitat- If you have downloaded the files within the first hour, your phone boots but the installer says that the framework is not installed, please download the updated version and flash again. XposedBridge version must be 61 afterwards.
Auch wenn dein Screenshot so ekelig groß is
... keine Sorge alles is richtig installiert. Sieht halt noch so aus
Teste ein Modul
... alles wird gut... und komme mir net mit Sachen wie: Aber Greenify sagt es ist net inst ...
hehe[Unofficial] List of working Modules for Xposed on Lollipop
Wieso groß, bei Tapa schaut es normal aus
Ja grad gesehen, hab mal greenify installiert
