Super SU v.2.76 stable
  • SuperSU v2.30 BETA - this one then?
    Nothing much wrong with v2.27, but it did have some issues installing on some devices with the very latest TWRP, based on Lollipop sources. This require some hussling around of the installation script
    So here's the next test. The full ZIP installer, the TWRP/CWM installer started in-app, and the "normal" installer start in-app have all been adjusted. Test results for all of these are welcome.
    Barring major reported issues, this version will start rolling out on the Play Store tomorrow.
    Let me know!
    SuperSU BETA thread on XDA: XDA
    Changelog
    - Layout adjustments for Nexus Player
    - Installer adjustments for latest TWRPs
    - Hiding icon now also hides from Leanback launcher
    - Icon replacements
    - ACCESS_SUPERUSER permission is gone
    https://plus.google.com/11351731947742…sts/1DJTvfjRFoe
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    [size=14]~~~~~~~~~~~~[/SIZE]
  • Stable/Play Store Update
    [COLOR=#ff0000]SuperSU 2.35, How-To SU, and CF-Auto-Root [/COLOR]
    @Google+
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Neue Beta ...
    [size=18][BETA][2014.11.28] SuperSU v2.36[/SIZE]
    28.11.2014 - v2.36
    - Use material theme on 5.0 when launched from settings
    - Fixed crash on 2.x and 3.x devices
    - Fixed TWRP installer issue for 4.2
    - Updated language files
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    Einmal editiert, zuletzt von MuggelPu (1. Dezember 2014 um 19:26)
  • Jap ... habt ihr recht ... eben auch im PlayStore 2.36 Update bekommen. Also Stable ... _/\_
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • :moustach:
    01.12.2014 - v2.37 (Gingerbread? )
    - Binary update requires less space on /system
    There will be no more changelogs.
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Beta-SuperSU-v2.38
    Changelogs
    07.12.2014 - v2.38
    - BETA
    - Watch for and kill dead per-uid daemonsu (SGS5 5.0 fix?)
    - Fix crash on clearing logs on 2.x
    - Fix possible NPE on open
    - Fix possible NPE on en/disable root
    - Moved additional donations to the bottom of settings
    - Small L theme adjustments
    [size=10]Device- [color=#660000]Nexus 6;[/COLOR][/SIZE]
    [size=12][COLOR=#4d4dff]GZR- Tesla[/COLOR][/SIZE]
  • BETA-SuperSU-v2.39.zip
    10.12.2014 - v2.39
    - BETA
    - Skip reverse connection watch on firmwares using supolicy (SGS5 5.0 fix?)
    - Fixed daemonsu not starting on truly permissive Lollipop
    - Adjust daemonisation code
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • [STABLE][2014.12.16] SuperSU v2.40
    - /system/su.d now executed for all daemonsu firmwares
    - Adjust sysinit context if present
    http://download.chainfire.eu/641/SuperSU/UP…retrieve_file=1
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • 17.12.2014 - v2.41 - BETA
    - Improved dumpstate work-around
    - Improved killing dead per-uid daemonsu
    - Backuptool support for Lollipop
    Chet Kener
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • BETA-SuperSU-2.42
    Changelog
    21.12.2014 - v2.42 - BETA
    - Fix rootfs remount issue that could lead to strange behavior on (for example) HTC M7 and M8
    - Backuptool support for /system/su.d
    - Some policy adjustments for CM12
  • [BETA][2015.01.03] SuperSU v2.43
    - Backuptool script adjusted again
    - Fix native NPE in username resolution
    - Fix some update failures when coming from a different root tool on 5.0
    - LD_PRELOAD sanitization
    - (C) 2015
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • [BETA][2015.01.07] SuperSU v2.44
    Soulflyer999 G+ Link
    07.01.2015 - v2.44 - BETA
    - su.d scripts no longer use logwrapper, this can prevent some scripts from running
    - supolicy timing adjustment (MotoG 2014 fix?)
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Ist doch schon stable oder?
    ;) :P
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Download UPDATE-SuperSU-v2.46.zip
    3.02.2015 - v2.46 - in staged Play roll-out
    - Backupscript adjustments
    - Remove more alternate su binaries
    THX ... @ mein geheimer Held ;)
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
