Original Post by [DLMURL="http://forum.xda-developers.com/showthread.php?t=2116432"]rfmalta[/DLMURL] / xda
This is the noob-proof multiuser enabler guide for the CM10.1 - GS3 only!!
Want to enable multiuser on your galaxy S3 under CM10.1?? This is the easiest way to do it.
Update 1 (based on build cm-10.1-20130204-NIGHTLY-i9300.zip)
1. Multi_user
This is very simple: just flash the zip file and you're done!! just need to create the users under settings!! Can create up to 5 users!!
P.S. You need to reflash these zips for every new nightly installed!!!!
Mehr Infos wie Installationshinweis Hier: [[DLMURL="http://forum.xda-developers.com/showthread.php?t=2116432"]KLICK[/DLMURL]]
Screenshots
