[KERNEL][Nexus 6] ElementalX-N6-1.05 [29.03.2015]
  • Achtung!!!
    Experimentelles Update auf 0.22
  • ElementalX v0.26 ist verfügbar: Schaut auch beim Dev vorbei und klickt THX ... ;)
    Keine Änderung zum Vorgänger mit dem Unterschied, dass man ihn jetzt auf SELinux permissive setzen kann für Mods wie Viper/Xposed
  • [size=18]1.02 is out! [/SIZE]
    Changelog
    -elementalX governor: remove input boosting and replace with active floor frequency
    -reduce hsic wakelock
    -default i/o sched is FIOPS
    -various tweaks and optimizations
  • Hier ist v1.05:
    There is also an update to the ElementalX app coming up.
    I added some new features to the color control screen. You can now load and save profiles. I added a few different test images. If you click on the image, it changes. There are some existing profiles. Thanks to @franciscofranco for providing them.
    There is new functionality in the Dashboard as well. I added an option to count deep sleep in the CPU time-in-state stats. You can access this screen by tapping the CPU info card on the Dashboard. You can also go directly to some of the other settings by tapping on the cards (Wake, GPU and I/O cards have this). I will be adding a few more new features to this when I can find the time.
    @bbedward suggested adding a tunable for his kernel (BFS rr_interval), so it's there too. But I didn't test it because ElementalX doesn't have BFS
  • Spoiler anzeigen
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    [size=14]~~~~~~~~~~~~[/SIZE]
  • Update!!!
    I think this version fixes the problem with occasional delayed wakeup. Let me know how it goes.
    Also a minor performance tweak and wifi updates.
    Download:
    ElementalX-N6-1.06
    Changes:
    -fix occasional delayed wakeups
    -wifi updates
    -disable crc check for better performance
    A
    Einmal editiert, zuletzt von Spevil (15. Mai 2015 um 09:47)
