QuoteDisplay More
[size=18][COLOR=#ff0000]Your warranty is now void. JK, this is NEXUS no voided warranties here![/COLOR][/SIZE]I am not responsible for bricked devices,
thermonuclear war, or you getting fired because the alarm app failed. Please
do some research if you have any concerns about features included in this ROM
before flashing it! YOU are choosing to make these modifications, and if
you point the finger at me for messing up your device, I will laugh at you.
A lot.
[size=18][COLOR=#ff0000]Please note the following:[/COLOR][/SIZE]
This is a very very very early preview. There's still a lot of work to do.
Right now, this is pretty much stock AOSP, features will be added when there is time, and we are able to do so!
Sound and video play back work flawlessly.
Kernel does not force encryption and will format all data if you flash on top of a forced encryption kernel.
This means you must backup all internal and SD storage onto a PC. It will wipe data, downloads, pictures, everything!
[size=18]Features[/SIZE][/LEFT]
"Features"
Under The Hood
AOSP Based
Un-encrypted
Theme Chooser
Customize Quick Settings
Delta Updates
Disabled tether checking
IME selector notification control
Advanced reboot
Adb notification control
Adb over network
Long press back to kill
CPU info overlay
Status bar brightness control
Superuser built into privacy gaurd
Battery Icons options
Option to disable lock screen carrier label
Slim heads up options
Headsup - don't show if notification drawer is visible
HeadsUp: Swipe options
-left swipe dismiss
-right swipe put into background
-swipe down opens notification drawer and moves the notification into it
USB OTG support
cLock widget
Notification weather panel
Disable battery saver bar color
Dialer - reverse number lookup
HSPA+ Icons
Statusbar clock and date customizations
Sound
AudioFX
Eleven
Increasing volume ringtones
Profiles
Increasing ring volume
Less frequent Notifications
Long Press Volume Keys to skip track
Disable volume adjust sound
Separate Ringtones & Notification volumes
Expanded Volume Panel
Navigation
Navigation bar options - Size & Hide
Left Handed nav bar in landscape
Double tap to wake
Sweep To Wake
Double tap statusbar to sleep
Wake on charge
Keyboard cursor control
Quick settings quick pulldown
Long Press recent buttons to switch apps
Long press back to kill app
Customize clear all button location
Security
Privacy guard with advanced app opp control
Blacklist for calls and sms
Dialer
Forward lookup
Speed dial
Vibrate on answer
MMS
Updated to material theme
Pinch and zoom conversation screen
Custom vibration patterns
Quick reply
Delay message timer
Mms import & export
Kernel
Based on HellsKernel
flar2 wake gestures
USB FastCharge
USB OTG
[LEFT]
[size=18]Installations Anleitung[/SIZE][/LEFT]
Installing Euphoria-OS for the first time, or coming from another ROM:
- Make sure you're running a proper working ClockworkMod-Recovery/Team Win Recovery Project - WITH SELINUX SUPPORT!
- Copy GApps and ROM ZIP to your SDCard
- If you are running an encrypted kernel, your data will be encrypted on first boot - Data will also be erased
- If you are running an unencrypted kernel, your data will remain unencrypted
- Boot into Recovery
- DO A DATA WIPE / FACTORY RESET
- Flash Euphoria-OS zip from SDCard
- Flash GApps zip from SDCard
- Flash SuperSU
- Reboot
- Don't restore system data using Titanium Backup!
Upgrading from an earlier version
- Copy the ROM ZIP to your SDCard
- Flash the ROM zip from SDCard
- Reboot
[LEFT][/LEFT]
Known Issues
**Sprint data not working. Flash this fix on initial flash with ROM
Thanks to:
First and most important thanks to Mahdi786
manelscout4life
Moose0704
teeseeuu
dr87
blazze11 - for bootanimation and drawables
TechXero for letting us use his server
eurochild - for providing us awesome graphics
hellsgod - for providing hells as our kernel base
Imoseyon
flar2
Slim-Roms
CM
Downloads
Euphoria-OS Site | Android File Host | Android File Sharing | Basketbuild
Changelog- Latest Version
Changelog Full
Contributors
dsmitty166, Mahdi786, manelscout4life, teeseeuu, eurochild
Source Code:https://github.com/Euphoria-OS
ROM OS Version: 5.1.1 Lollipop
Based On: AOSP
[LEFT]
[/LEFT]
[COLOR=#ff0000]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.
ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht.[/COLOR]
[LEFT][COLOR=#ff0000]
[size=12]Quelle[/SIZE][/COLOR][/LEFT]
