ZitatAlles anzeigenand help yourself.
platform/build
9cc9373 "LRX22C"
ff8b5b1 "LRX22B"
ced3fdc "LRX21Z"
205c1f8 "LRX21Y"
4eab14a "LRX21X"
30de1b6 Increment Android versions to 5.0.1
988ef2c "LRX21W"platform/cts
65f1d9c cts: add TestLog tags to XML reportdevice/asus/flo
1ae9de5 flo: increase vmalloc size by 100MB (240MB-->340MB)device/sample
3060078 Updating Claro PR MMS APN (330-110)
d70ca8e Updating Y!Mobile Japan APN config (440-20)platform/external/chromium_org
44393df Update volantis workaround to cover L mr0.1platform/external/wpa_supplicant_8
1d13911 Work around AP misbehavior on EAPOL-Key descriptor versionplatform/frameworks/base
93edcc1 Fix null handling in proxies.
8de29d6 Setting ADB_ENABLED may result in a SecurityException.
9e3db14 Add configuration to control converting sms destination number
f140844 Increases the falsing threshold when for the keyguard affordances
17cc44f Import translations.platform/frameworks/opt/telephony
477b0fb Add configuration to control converting sms destination numberplatform/packages/apps/Contacts
5402f10 Switch from CALL -> CALL_PRIVILEGEDplatform/packages/apps/ContactsCommon
2523f0e Switch from CALL -> CALL_PRIVILEGEDplatform/packages/apps/Dialer
140247d Switch from CALL -> CALL_PRIVILEGEDplatform/packages/apps/InCallUI
aaebf54 Send DTMF tones for dialing callplatform/packages/apps/Settings
c586786 Prevent factory reset for short passwords in CryptKeeperplatform/packages/services/Telecomm
4761b1b Allow calling of voicemail using CALL_PRIVILEGEDplatform/prebuilts/android-emulator
575a7f1 am ade43fa8: Update: Fix emulation of older platforms.
9e0c287 update: Parse ramdisk.img to detect partition formats.platform/prebuilts/qemu-kernel
2cd41c7 Upgrade qemu kernels to support multinetwork.
5f91f38 Merge "Update ARM and x86 kernel 3.4 images."
Na dann hoffen wir mal das beste... Habe es per fastboot geflasht. Bis jetzt positiv überrascht!
