[GUIDE]Nexus 9 back to stock guide - Unbrick - Restore factory firmware
  • The aim of this thread is to make an easy guide to flashing stock firmware. Owners of previous nexus devices already know all this stuff, this thread is aimed at making the process as simple as possible for new users. This will work regardless of what modifications you've done to your device. Remember to backup all your important data and do this with the knowledge that all flashing activity carries some risk.
    Download
    Factory image here
    (for windows users) Minimal adb & fastboot
    (for mac users) adb & fastboot for mac
    Follow the instructions to install adb on your computer.
    Prepare your tablet
    Enable developer options in settings > about tablet and tapping build number 7 times
    Open developer options and enable usb debugging. (If you haven't unlocked your bootloader yet, tick enable oem unlock)
    Extract images
    Place the downloaded factory image inside your adb folder and extract with 7zip.
    A new folder will be there called something like volantis-lrx21. Open and extract "image-xxxxx-zip" to your adb folder. We are interested in these files:
    bootloader-flounder-xxxxxx.img
    boot.img
    recovery.img
    cache.img
    system.img
    vendor.img
    Place these files directly into your adb folder.
    # I recommend renaming the 'bootloader-flounder-xxxxxx.img' to just 'bootloader.img' to make it easier to type.
    Now that everythings set up, we can start flashing
    Plug in your device. Open the adb folder, hold shift and right click and select open command window here
    (if your having driver issues try using Pdanet)
    Run these commands one at a time
    adb devices
    adb reboot bootloader
    if you haven't unlocked the bootloader yet run
    fastboot oem unlock
    and follow the instructions using the volume keys to scroll through the menu. This procedure will wipe all data.
    Run the following commands one at a time
    fastboot flash bootloader bootloader-flounder-xxxxxxx.img
    (replace 'bootloader-flounder-xxxxx.img' with full name of bootloader image)
    fastboot reboot-bootloader
    fastboot -w
    fastboot flash boot boot.img
    fastboot flash recovery recovery.img
    fastboot flash cache cache.img
    fastboot flash system system.img
    fastboot flash vendor vendor.img
    (OPTIONAL) At this stage you can relock the bootloader if you want by running the command
    fastboot oem lock
    finally reboot the device by running
    fastboot reboot
    Thats it. Enjoy your tablet in factory condition
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    [size=14]~~~~~~~~~~~~[/SIZE]
