Eine wirklich MEGA ROM!!! Have fun!
Few notes:
- Everything has been written from scratch, even common features have been perfected and improved.
- Quality and stability first.
- Cataclysm uses an unique way to merge AOSP with Stock image. more
- Cataclysm gives you a 100% Google experience plus other features.
- There won't ever be any theme chooser, ever.
- Cataclysm won't ever include anything you can easily get with an app.
- Cataclysm is rooted (powered by SuperSU - Google Play / XDA), with Stericson busybox (Google Play) and comes with Gapps.
Please read the FAQ and release notes in changelog.
Download Cataclysm from AndroidFileHost
[DLMURL="https://s.basketbuild.com/devs/atl4ntis/HAMMERHEAD_NEXUS_5"]Download Cataclysm from BasketBuild[/DLMURL]
Download Cataclysm from DevHost
Layers/RRO Themes Sammlung
https://www.android-port.de/themen/theme-l…hemes-vor.6628/
MODIFICATIONS AND REDISTRIBUTIONS ARE NOT ALLOWED
SCREENSHOTS
CHANGELOG
"Lollipop Changelog: KLICK mich!"
Sep 09, 2015: Sources updated to android-5.1.1_r14 (LMY48M)
Sep 06, 2015: Clear all notifications button on status bar.
Sep 06, 2015: Layers 2.1 support.
Aug 07, 2015: Sources updated to android-5.1.1_r9 (LMY48I). Cataclysm Aug 07, 2015 Beta Release (524MB)
Aug 07, 2015: Layers: SystemUI toggles FC fix, fix sorting of overlays list.
Jul 10, 2015: Layers: expose toggles rearrange and lockscreen wallpaper dialog text.
Jul 02, 2015: Lockscreen: double tap to sleep. [COLOR=Red]Cataclysm Jul 03, 2015 Nightly Update[/COLOR] (9MB) Release notes
Jul 01, 2015: Fixed possible Smart Radio white list settings FC on first launch.
Jul 01, 2015: Lockscreen: Allow cropping wallpaper vertically.
Jul 01, 2015: Color picker: less cryptic default button.
Jun 26, 2015: Longpress status bar settings wheel for Cataclysm settings.
Jun 25, 2015: Hide bluetooth status bar icon when disconnected.
Jun 25, 2015: Wake on notif: make pocket extraction detection optional.
Jun 20, 2015: Show Deep Sleep on Stats tile. [COLOR=Green]Cataclysm Jun 20, 2015 Stable Release[/COLOR] (524MB) Release notes
Jun 20, 2015: Fixed status bar double tap glitch.
Jun 19, 2015: Wake on notification pocket detection: misc fixes.
Jun 19, 2015: Quick Toggles: USB Tether. [COLOR=Red]Cataclysm Jun 19, 2015 Beta Update[/COLOR] (25MB) Release notes
Jun 18, 2015: Show status bar clock on keyguard.
Jun 18, 2015: Proximity speaker: disable on audio mode changed by user untill end of the call.
Jun 18, 2015: Proximity speaker: misc BT fixes.
Jun 17, 2015: Don't fully expand QS when tapping on statusbar with quick pulldown or two fingers.
Jun 17, 2015: Wake on notification: wake if pulled out of pocket within 10 sec.
Jun 14, 2015: Hide Keyguard Clock/Date/Alarm. [COLOR=Red]Cataclysm Jun 14, 2015 Beta Update[/COLOR] (25MB) Release notes
Jun 12, 2015: Cataclysm features now fully support multiuser.
Jun 11, 2015: Layers: fix multiuser dialog text white over white.
Jun 11, 2015: Quick Toggles: Quick pulldown: Drag mode.
Jun 11, 2015: Wake on notification: don't wake if phone is in bag/pocket.
Jun 11, 2015: Use B/s KB/s MB/s instead of B KB MB in network speed stats tile.
Jun 10, 2015: Don't fully expand QS when tapping on statusbar with quick pulldown or two fingers.
Jun 10, 2015: Don't truncate time elapsed since last charge on some languages.
Jun 10, 2015: Allow reposition of clear all recents button.
May 21, 2015: Sources updated to android-5.1.1_r3 (LMY48B). [COLOR=Red]Cataclysm May 21, 2015 Beta Release[/COLOR] (532MB) Release notes
May 11, 2015: Ringer Mode custom intents for Normal/Vibrate/Silent.
May 02, 2015: Cataclysm Settings app shortcut.
Apr 25, 2015: Smart Timeout: disable while on secure lockscreen.
Apr 24, 2015: Prevent soft reboot caused by getCameraInfo() stock bug.
Apr 16, 2015: Global Force headsup notifications along with per-app settings.
Apr 16, 2015: Reintroduce Global Wake on notification along with per-app settings.
Apr 16, 2015: Don't hide Rotation tile if disabled from accessibility.
Apr 16, 2015: Fixed NFC Tile disappearing.
Apr 13, 2015: Speaker follows proximity: disable while bt/wired headset is connected. Cataclysm Apr 14, 2015 Stable Release (532MB) Release notes
Apr 10, 2015: Smart Timeout: fixed camera busy issue. Cataclysm Apr 10, 2015 Beta Update (26MB) Release notes
Apr 10, 2015: Smart Timeout: won't activate (more then once) if screen is forced active.
Apr 10, 2015: Speaker follows proximity: added delay, sync dialer icon/button with speaker.
Apr 05, 2015: Security input prio: fixed insecure lockscreen not showing on first boot.
Apr 05, 2015: Smart Timeout: cleanup/misc fixes/improvements.
Apr 05, 2015: Don't kill dialer if any call is on hold.
Apr 04, 2015: Wake on notification moved to per-app settings. Cataclysm Mar 15, 2015 Beta Update (26MB) Release notes
Apr 04, 2015: Speaker follows proximity sensor while in call.
Apr 04, 2015: Smart Timeout beta.
Apr 04, 2015: Zen background for custom blocked numbers/contacts.
Apr 02, 2015: Fixed white notification title under some conditions.
Apr 02, 2015: Security input priority: no notifications.
Apr 02, 2015: Fixed Sprint issue.
Mar 31, 2015: Readded softkeys padding. Cataclysm Mar 31, 2015 Beta Release (532MB) Release notes
Mar 29, 2015: [RRO] Layers support.
Mar 28, 2015: Sources updated to android-5.1.0_r3 (LMY47I).
Mar 28, 2015: BSS: use exact alarm instead of optimized.
Mar 28, 2015: Lowered end margin when hiding battery.
Mar 28, 2015: Lockscreen options: disable albums art.
Mar 28, 2015: Lockscreen options: security input on top priority (never/no clearable notifications/always).
Mar 28, 2015: Lockscreen options: opacity slider.
Mar 28, 2015: Lockscreen: fixed ghostly glitch on album art (aosp bug).
Mar 28, 2015: Allow fine grain animations control up to 2x speed (up from 1x).
Mar 21, 2015: Fixed recents animation glitch. Cataclysm Mar 21, 2015 Stable Release (577MB) Release notes
Mar 20, 2015: Battery saver: 0-100 low battery values (slider).
Mar 19, 2015: SmartRadio: correctly listen for Data on/off changes.
Mar 17, 2015: Cataclysm backup date/time is again localized.
Mar 17, 2015: Fixed Volume Music control needing a reboot to make it working once enabled.
Mar 17, 2015: Smart Radio: re-added custom intent to enable it from the outside.
Mar 17, 2015: Smart Radio: added two different delays for Low and High power switch.
Mar 15, 2015: Disabled SystemUpdateService wakelock for good. Cataclysm Mar 16, 2015 Beta Update (16MB) Release notes
Mar 15, 2015: Smart Radio: delayed switch.
Mar 15, 2015: Smart Radio (Beta): rebuilt from the ground up.
Mar 14, 2015: Attempt to disable SystemUpdateService without wakelocks. Cataclysm Mar 15, 2015 Beta Update (16MB)Release notes
Mar 14, 2015: Stock-a-like animation to custom toggles.
Mar 14, 2015: Readded notification volume slider, if unlinked, on sound settings options.
Mar 14, 2015: Disable led on priority mode/no interruption.
Mar 14, 2015: Animate recents and recents button like new dismiss notifications button.
Mar 14, 2015: Don't flip custom toggles icons on RTL languages.
Mar 14, 2015: Center glow when pressing battery with no labels on status bar.
Mar 14, 2015: SoftkeysFadeMod: center dots when ime is enabled.
Mar 11, 2015: Sources updated to android-5.1.0_r1 (LMY47D). Cataclysm Mar 12, 2015 Beta Release (577MB) Release notes
Mar 11, 2015: Disable recents search widget.
Mar 11, 2015: Wake on notification: misc fixes.
Feb 28, 2015: Hide IME switcher.
Feb 28, 2015: Haptic feedback for cursor arrow keys (if enabled system wide).
Feb 26, 2015: Swipe HeadsUp up for an early timeout. Cataclysm Feb 27, 2015 Stable Release (502MB) Release notes
Feb 26, 2015: Fixed navigation bar cursor keys being too tiny on stock dpi.
Feb 26, 2015: Fixed Circular battery text misaligned at different dpi.
Feb 26, 2015: Pulse led color chooser, removed redundant disable checkbox.
Feb 26, 2015: Fixed oval default led color picker.
Feb 26, 2015: Correctly handle silent mode while in priority mode aswell.
Feb 25, 2015: Fixed low battery pulse led color.
Feb 25, 2015: Allow silent mode to be set with volume down key. Cataclysm Feb 25, 2015 Nightly Update (26MB) Release notes
Feb 25, 2015: Circular battery.
Feb 24, 2015: Wake on notification: misc fixes.
Feb 24, 2015: Navigation bar cursor control.
Feb 22, 2015: Hide status bar on lockscreen.
Feb 22, 2015: Hide carrier label.
Feb 21, 2015: Led control: new colors, color picker dialog.
Feb 20, 2015: Led control: default notification led color.
Feb 19, 2015: Notification control: Wake on notification. Cataclysm Feb 19, 2015 Nightly Update (26MB) Release notes
Feb 19, 2015: Notification control: Expand all notifications.
Feb 18, 2015: Notification control: Custom headsup timeout.
Feb 18, 2015: Led control: Notification led: priority to first/last, On/Off time.
Feb 18, 2015: Led control: Charging led: custom colors, priority to charge/notification, On/Off time.
Feb 12, 2015: Raise vol panel timeout and show zen modes when controls always music is active.
Feb 11, 2015: Lockscreen shortcuts: none, shortcut.
Feb 10, 2015: BSS: reenable on unplug if in range and disabled cause plugged.
Feb 10, 2015: BSS: don't disable if enabled cause low battery.
Feb 09, 2015: Per-app settings: custom LED "none" option.
Feb 06, 2015: Battery saver scheduler: misc fixes. Cataclysm Feb 06, 2015 Nightly Update (26MB) Release notes
Feb 05, 2015: Per-app settings: custom LED color.
Feb 04, 2015: Volume controls always music stream.
Feb 04, 2015: Battery saver scheduler.
Feb 01, 2015: Per-app settings: custom Locale.
Feb 01, 2015: Per-app settings: custom DPI.
Jan 31, 2015: Per-app settings: allow background data while on battery saver mode.
Jan 31, 2015: NFC polling mode: fix screen on locked.
Jan 26, 2015: Per-app settings: AppOps.
Jan 25, 2015: Softkeys Fade Mod.
Jan 21, 2015: Disable low battery led even if already lit. Cataclysm Jan 23, 2015 Stable Release (502MB) Release notes
Jan 21, 2015: Show restrict mobile background data preference in Per-app settings aswell.
Jan 20, 2015: Display the time elapsed on battery since latest full charge on battery stats.
Jan 20, 2015: Disable battery saver orange bars.
Jan 19, 2015: Swipe2sleep is again optional. Cataclysm Jan 19, 2015 Nightly Update (25MB) Release notes
Jan 19, 2015: Fixed possible network mode issue due to Smart Radio race condition even when disabled.
Jan 19, 2015: Volume wake: adjust volume while in call, press volDown and volUP at same time to wake.
Jan 17, 2015: Swipe2sleep: misc fixes.
Jan 17, 2015: Disable low battery blinking led.
Jan 16, 2015: Cataclysm settings: entries are now indexable and appear in Search bar.
Jan 15, 2015: SmartRadio: don't downgrade if wifiAp is active.
Jan 15, 2015: Per-app settings: force headsup, disable headsup if available.
Jan 15, 2015: Per-app settings: block lockscreen notifications, block ongoing lockscreen notifications.
Jan 13, 2015: Swipe to sleep: fine tuning, fix landscape orientation.
Jan 13, 2015: Wider landscape notification panel/quick settings layout.
Jan 13, 2015: Volume cursor control (inverted).
Jan 09, 2015: Navigation bar swipe to sleep. Cataclysm Jan 10, 2015 Nightly Update (19MB) Release notes
Jan 09, 2015: Allow locking current landscape orientation with rotation toggle.
Jan 09, 2015: Close dialer on hangup only if is foreground.
Jan 09, 2015: Fixed disable QS on secure lockscreen still showing them under some conditions.
Jan 08, 2015: Backup: correctly restore "Hide alarm icon" and "Close dialer on hangup" values.
Jan 08, 2015: Fixed FC restoring backups with animations scale and/or smart radio never used.
Jan 07, 2015: Longclick expanded clock/date for clock app.
Jan 07, 2015: 3G only/LTE only network modes.
Jan 07, 2015: QuickToggles: Volumes.
Jan 05, 2015: Center toggle's icons (and glow) and regain wasted space when hiding labels.
Jan 05, 2015: Fixed battery text not showing below 5% under certain conditions and styles.
Jan 03, 2015: Hide persistent alarm icon. Cataclysm Jan 04, 2015 Nightly Update (11MB) Release notes
Jan 03, 2015: Close dialer on hangup.
Jan 03, 2015: Show menu on both sides.
Jan 02, 2015: Settings backup.
Jan 02, 2015: Hide brightness slider.
Jan 02, 2015: Quick Toggles: resize, hide labels, custom columns, unify, longclick.
Jan 02, 2015: Expandable volume panel.
Dec 23, 2014: Battery styles: misc fixes. Cataclysm Dec 24, 2014 Stable Release (502MB) Release notes
Dec 23, 2014: Don't show default shortcuts preview on custom shortcuts launch.
Dec 23, 2014: Fixed right shortcut not working on secure lockscreen for some users.
Dec 22, 2014: Fixed custom wallpaper lag. Cataclysm Dec 22, 2014 Nightly Update (32MB) Release notes
Dec 22, 2014: Led support for charging (optional).
Dec 22, 2014: Led support for missed calls (default).
Dec 21, 2014: Disable material glow for pinpad clicks.
Dec 21, 2014: Retuning icon + inner text battery style.
Dec 20, 2014: Custom swipe left/right lockscreen shortcuts.
Dec 19, 2014: Fixed notification volume auto unlinking from ringer on reboot.
Dec 17, 2014: Smart radio: apps white list. Cataclysm Dec 17, 2014 Beta Release (502MB) Release notes
Dec 17, 2014: Longpress back to kill: don't kill pinned apps right after unpinning them.
Dec 17, 2014: InCall Blocker original + custom numbers.
Dec 16, 2014: Custom animations speeds.
Dec 16, 2014: Sources updated to android-5.0.1_r1 (LRX22C).
Dec 14, 2014: Force show menu on navbar.
Dec 14, 2014: Hide phone number to unknown.
Dec 11, 2014: Disable autorun for apps on AppOps. Fixed another index out of bounds error (aosp bug).
Dec 10, 2014: Volume rocker music control. Cataclysm Dec 10, 2014 Nightly Update (14MB) Release notes
Dec 10, 2014: Disable Heads up notifications.
Dec 09, 2014: Enable notification ticker.
Dec 08, 2014: Quick Toggles: Battery saver.
Dec 08, 2014: Custom lockscreen wallpaper. Will temporarily hides on media album art showing.
Dec 08, 2014: Raised multimedia volume steps to 21, up from 15.
Dec 08, 2014: Disable Nfc sounds, vibrate instead.
Dec 08, 2014: Nfc polling modes (Screen on unlocked/Screen on locked/Screen off)
Dec 07, 2014: Unlink notification volume.
Dec 04, 2014: Fixed battery scaling on non standard dpi. Cataclysm Dec 05, 2014 Stable Release (502MB) Release notes
Dec 04, 2014: Disable QS on secure lockscreen now works for every quick pulldown modes.
Dec 03, 2014: Battery Styles: Stock / Stock + Inner Text / Text only / Gone. Cataclysm Dec 03, 2014 Nightly Update (10MB)Release notes
Dec 02, 2014: Quick Toggles: Network mode (2G/3G/LTE) - Gps.
Dec 02, 2014: Quick Toggles: System Stats (CPU speed/temp - Network speed download/upload - Memory available (real, includes cached).
Dec 01, 2014: Longpress reboot in powermenu for hotreboot (zygote restart).
Dec 01, 2014: Quick Toggles: RingerMode (normal/vibrate/silent/priority/none).
Nov 29, 2014: Quick Toggles: Screenshot - Nfc - Sync - Screen Timeout.
Nov 29, 2014: Longpress back to kill won't kill screenpinned apps.
Nov 29, 2014: Disable Quick Settings expansion on secure lockscreen.
Nov 29, 2014: Clear all recents button is now optional.
Nov 29, 2014: Reboot entry in powermenu is now optional.
Nov 27, 2014: Fixed switches in appops detail being out of the view sometimes (aosp bug). Cataclysm Nov 27, 2014 Nightly Update (10MB) Release notes
Nov 27, 2014: Temporarily fixed animation when pulling directly QS without notifications and while not on lockscreen (aosp bug).
Nov 26, 2014: Lockscreen rotation.
Nov 26, 2014: AM/PM on status bar clock.
Nov 26, 2014: Center status bar clock.
Nov 26, 2014: Quick PIN unlock.
Nov 25, 2014: Volume rocker wake: correctly eat the volKey after waken.
Nov 25, 2014: Fixed sleep button overlap with QS Header switch when closing QS with showdetails.
Nov 24, 2014: Aggressively disable Play Services System Update causing wakelocks for some users. Cataclysm Nov 24, 2014 Beta Release (501MB) Release notes
Nov 24, 2014: Fixed sleep button overlap with QS Header switch when toggling QS details.
Nov 24, 2014: Shortened longpress back to kill the foreground app to 1s (down from 2s).
Nov 24, 2014: Disable status bar clock.
Nov 24, 2014: Disabled dun required for Wifi tethering.
Nov 24, 2014: Volume rocker wake. Press both volUp and volDown to wake if music is playing.
Nov 24, 2014: Moved clear recent button up for pie users. Faster/smoother animation. Fix showing when not needed.
Nov 24, 2014: Vibrate on call remote pickup/hangup. One for pickup, two for hangup.
Nov 22, 2014: Delete button on screenshots notifications. Cataclysm Nov 22, 2014 Beta Release (501MB) Release notes
Nov 21, 2014: QuickToggles haptic feedback.
Nov 21, 2014: QuickToggles quick pulldown (six modes).
Nov 21, 2014: QuickToggles rearrange for default toggles.
Nov 21, 2014: QuickToggles choose for default toggles.
Nov 21, 2014: Expanded date clickable go to calendar.
Nov 21, 2014: Exposed AppOps. Fixed index out of bounds error (aosp bug).
Nov 20, 2014: Disabled system update.
Nov 20, 2014: Volume key cursor control.
Nov 20, 2014: Disable full screen keyboard.
Nov 20, 2014: Disable power menu on secure lockscreen.
Nov 20, 2014: Smart Radio.
Nov 19, 2014: Sleep button on status bar. Longpress for power menu.
Nov 18, 2014: Clear all recents button on navbar. Won't kill the task from which is invoked and go back to it.
Nov 17, 2014: Disable low battery warning.
Nov 17, 2014: Disable wake when (un)plugged.
Nov 17, 2014: Allow 180° rotation.
Nov 17, 2014: Longpress recent to last task. Move task to front or reopen.
Nov 17, 2014: Led notification light shortened to 3 sec (down from 7).
Nov 17, 2014: Longpress back to kill the foreground app. Also remove it from recents.
Nov 16, 2014: Disable GoogleNow gesture.
Nov 16, 2014: Disable volume adjust beep.
Nov 16, 2014: Added proper resource for ime key land.
Nov 16, 2014: Disable adb notification.
Nov 16, 2014: Navigation bar resize. Icons scale down only below 75%. Optional portrait only.
Nov 16, 2014: Extended power menu - Reboot.
Kernel sources are HERE
* Implement kexec-hardboot - <vbocek@gmail.com> Tassadar - Vojtech Bocek et al.
* hammerhead kernel: implement always on rgb led support - <sam@mortimer.me.uk> Sam3000 - Sam Mortimer
* lights.hammerhead.so: hammerhead: add charging led support - <sam@mortimer.me.uk> Sam3000 - Sam Mortimer
* leds: At disable, set the trigger to default instead of wiping it - <cyanogenmod@cerqueira.org> rmcc - Ricardo Cerqueira
"FAQ"
FAQ
I'm reading the FAQ, am i good?
- You sir are the best.
There's anything missing? Gapps?
- Everything is included, root, Gapps and busybox, no need to flash anything else.
- Please avoid flashing third party Gapps.
How can i get rid of Gapps i don't use?
- I suggest to disable them instead of removing them so they won't reappear when you flash an update over.
- No need for third party apps for such task, just go to settings --> all apps managment and hit the disable button,
- after previously uninstalling possible updates first.
Is Cataclysm heavily themed?
- No, Cataclysm is 100% stock themed. All extra features are disabled by default.
- Installing it without enabling anything will result in a 100% stock experience.
How should i install Cataclysm?
- Do a Wipe/Factory reset and then flash. Strongly suggested to update to latest recovery.
- Should be safe to dirty flash new releases over the old ones unless android version bump.
- Cataclysm won't update radio or bootloader for you so you gotta do it yourself.
- If coming from KitKat i suggest to flash Google Factory images first to avoid "sdcard" issues,
- and to update the radio and bootloader.
- Be carefull as it will erase your sdcard datas.
Why there are multiple install packages and how should i flash them?
- If you're not on Cataclysm already, just install latest full stable release.
- If you already have Cataclysm installed, just flash the latest nightly update (no wipe needed).
- The nightly update can be flashed over latest Cataclysm Lollipop stable release.
I get error when flashing Cataclysm
- First make sure to compare the md5 against the one on the file hosting site.
- Don't wipe system. Don't mount system. If you did, reboot again to recovery before flashing.
- Installer for full releases and update zips have been tested as working so any issue you have is on your side only.
Support to adb remount / init.d scripts.
- These features need a custom kernel, please refer to your best kernel dev.
New sources are up, why don't you update your rom?
- I will once Google Factory images are up for our device.
SD card issue, permission denied, 32gb instead of 16gb, files missing.
- sdcard problems upgrading android thread
Smart Radio is grayed out.
- Smart Radio is not available for CDMA users.
Network Mode toggle is grayed out.
- Network Mode toggle is not available for CDMA users.
Gallery app is missing.
- Gallery app is no longer available on Stock Lollipop.
- You may flash this zip to have it back, no wipes are needed.
My lockscreen keeps showing the album art despite i've stopped listening to music.
- It's a known AOSP issue. Make sure you exit correctly the music app,
- either by swiping the notification or by exiting with the menu. Don't kill the app.
- If it's killed by some memory managment, just reopen and exit it, no need to reboot.
- Actually Tune In radio is bugged on stock aswell, you can launch an album with Play music and exit to reset the lockscreen.
I got this bug.
- Lollipop is a fresh release and comes with many bugs, here's a list of common ones, not related to Cataclysm itself:
- Torch bugs out the camera.
- Search bar widget missing from recents.
- Lags, apps closing themselves after days of usage without rebooting.
- No silent mode.
- Apps reappearing in recents view after clearing them.
- Wifi connection issues and battery drain.
- Notifications issues.
- Caller pic not always showing.
My home/back button, notification pulldown isn't working after a dirty flash
- Open a terminal emulator on the phone and digit:
- su (enter)
- am start -n com.google.android.setupwizard/.SetupWizardTestActivity (enter)
- follow the instructions and possibly reboot after.
Can't select AM/PM clock style
- You can't select it if you're using the 24Hour clock format.
Volume wake doesn't wake the device.
- When music is playing you need to press both volUp and volDown, to avoid waking the device when adjusting volumes.
I have radio/signal/gps issues
- Those issues aren't and won't ever be related to Cataclysm.
- Make sure you're on latest radio available in Google Factory image.
- Any issue about them is on your side only.
Smart Radio disconnect me on switch, it also takes seconds to reconnect
- It's normal to get disconnected when you switch radio
- The switch is handled by the radio itself, can't make it better nor faster.
- If you want a seamless switch and still saving battery, just enable it without any other options and it will switch only
- when you're connected/disconnected from wifi or mobile data is enabled/disabled.
Why wifi is always enabled on battery stats even if i turn it off?
- Play services by default uses wifi for location services even when it's "off".
- Go to Wifi --> Advanced Settings --> Wifi scan always available to disable it.
- If it still shows keep in mind this happens on stock rom aswell, whether a bug or not.
May i suggest/request something?
- Constructive feedbacks are appreciated.
- Keeping asking for the same features over and over won't make them implemented sooner.
- Posts like "Add this feature cause that rom has it" or "Add this feature, here's the code" are not welcome
- and are considered offensive.
Why didn't you answer to my post/pm?
- I try answering to all the relevant questions posted on thread whenever i can.
- I won't answer in PM to questions that can be posted on thread.
- I won't answer to posts that are already covered by this faq, but ironically you won't know this.
I'd love to translate Cataclysm, how can i help?.
- Send me a PM for more info.
Pls buddy I want ur mods from the catacalysm, can I have ur codes of some of ur mods that u put in the catacalysm ROM?
- Unfortunately Cataclysm sources aren't publicly available and won't ever be.
Quelle: this zip
[B][B][B][COLOR=#ff0000]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.[/COLOR]
[B][COLOR=#ff0000]ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht.[/COLOR][/B][/B][/B][/B]
