So these builds will be pretty pure Stock CM12 builds + some very carefully selected (and tested) cherry-picks from CMs gerrit/code review.
This will not be a rom where features will be added from other ROMs. Features will be strictly CyanogenMOD and will be on their gerrit.
BUGS:
- APN settings need to be manually entered
- You tell me!
DOWNLOADS
MIRROR 1 - ANDROIDFILEHOST
"Changelog"
(not complete, check Gerrit Code Review or CM12 Nightlies Changelogs for all the merged changes)
06.02.2015
- Synced latest CM source
- Stylus gestures features
- input: Add option to toggle pointer icon when using stylus
- settings: Fix the custom screen color controls
- SystemUI : Improve nav ring swipe behavior
- Reverted the 2.0A charging
05.2.2015:
- Synced CM source up to date
- Enabled 2.0A charging (faster charge time)
- fixes to SetupWizard
- Theme fixes
- Camera can now use power key as a shutter button
- Lockscreen shortcuts can now be disabled
04.2.2015
- Fixes to the new CM SetupWizard
- Theme Engine fixes
- Updates to Trebuchet (CM launcher)
- cherry-pick USB OTG should now be fully working (thanks @gladiac)
- cherry-pick Custom LCD Density
03.02.2015
- Navring customizations
- Whisperpush lollification
- No forced encryption for /data
- cherry-pick flounder: USB OTG support
01.02.2015
- APN fix (thanks to @zawata) after a factory reset
- Update bootanimation (should now be a dark version)
- cherry-pick Extra settings under wifi tile in QuickSettings
29.01.2015
- Synced CM source
- Kernel set to not force encryption
- Settings : Add screen timeout tile
- cherry-pick Wifi: add option to show quick settings detail view
27.01.2015
- Synced latest cm source
- SystemUI: Lte -> LTE
- Add 2048x1536 boot animation
- Settings: add AudioFX tile
- cherry-pick Navring targets customization
26.01.2015
- First public build
- Theme fixes
Quelle
