"Informationen"
Hi guys!
Let's go for the shamu!
I'm presenting my kernel [COLOR=Blue]Code_Blue[/COLOR], that started as an addon for Purity ROM, called Purified Kernel.
Some of you know me from other Nexus devices asked me to bring the project, so I did.
My releases are Dragon_Shield powered and I'm going to share them with you.
All I want is full smoothness, performance and battery on my hammerhead, so I build always with Linaro optimized Cortex A15 toolchains.
I aim for a "stockish feel" lean build and for stability purposes I will stay with GCC 4.9.3 for now.
Code is based of android-msm-shamu-3.10-lollipop-release, forked from android/kernel_msm.
Useful and powerful picks are mandatory
[size=14][COLOR=blue]Be sure to join Code_Blue users [/COLOR]G+ community[/SIZE]
You keep the spirit alive!
[size=18][COLOR=#000000]Kernel features:[/COLOR][/SIZE]
- Build on Ubuntu 14.04.2 x86_64 (Dragon_Shield VPS @ [DLMURL]http://www.servercore.com.br%5b/DLMURL] - thanks @ChristianLetti)
 - Build with toolchain Linaro 2015.03 Cortex-A15 GCC 4.9.3 by @Christopher83
 - Full -O3 & graphite support with device and target flags enhanced, linaro build improvements, etc
 - Based on android-msm-shamu-3.10-lollipop-mr1 + own commits & cherry-picks on demand from code aurora, linaro, etc.
 - Kernel compressed with LZ4-r127, custom tweaked RAMdisk with GZIP (faster boot times, removed force encryption)
 - Removed some debug and logging options
 - Enhanced performance and battery patches
 - Several CPU Governors (blu_active own governor is default)
 - Voltage Control UV_mV_table
 - Enhanced TCP methods (westwood is default), Network and Wifi tweaks
 - Several I/O control (FIOPS is default), tweaked filesystems (F2FS, ExFAT, NTFS & CIFS available)
 - Disabled stock mpdecision and thermald
 - blu_plug: Dynamic hotplug for shamu, with screenoff battery saving (max dual core @ max_freq 1190400)
 - Motorola quickwakeup driver
 - Lollipop msm_thermal temp tunable (default 70º C threshold)
 - Optimized RWSEM, AES and SHA1 routines (with neon support)
 - Vibrator Strength tunable (75 level ~ 60 % default)
 - KGSL fixes and reworked GPU driver (removed doubled freqs, goes to idle @ 27MHz), Simple GPU Governor extensions
 - KCAL - Advanced color control for Qualcomm MDSS v3 (RGB calibration and post-processing features)
 - Faux Sound Control (on/off switch available), with In-call and headphone volume controls (must use FauxSound beta app v1.2.3 and up)
 - USB Fast Charge (USB mode up to 900mA with MTP mode on)
 - Wakelock on/off switch (smb135x, sensor_ind & msm_hsic_host)
 - init.d support (busybox run-parts required), Kernel cleaner script
 - Compatible with Kernel Adiutor, Universal Kernel Manager, TricksterMOD, Device Control, Kernel Tweaker and FauxSound Control
 - Featured on Rom Directory by @tFrost
[size=18]Download & Changelog[/SIZE]
[size=14][COLOR=#000000]Download latest [/COLOR][COLOR=blue] Code_Blue Kernel[/COLOR] [/SIZE]zip, flash in recovery and profit.
No mirrors allowed. Don't post hardlinks, use original links.
Also don't make repacks and/or use with inline ROM builds without permission.
[COLOR=green][size=18]Changelog[/SIZE][/COLOR][size=14] is available @ website also on [/SIZE][size=18][COLOR=#000000][DLMURL="https://github.com/engstk/shamu-5.0"]github[/DLMURL][/COLOR][/SIZE][size=14] link.[/SIZE]
[COLOR=red][size=18]Warning[/SIZE][/COLOR]:
If you come from other kernel, you should dirty flash your ROM before flashing Code_Blue zip to avoid problems.
Reflash ROM -> flash SuperSU -> Boot device and install busybox -> flash Code_Blue.
Also uninstall or clean data of any kernel control app you're using.
[COLOR=#ff0000]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.
ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht.
[/COLOR]
[size=10][COLOR=#000000]G+[/COLOR][/SIZE]
