Schade, schon wieder einer abgewandert zum unübersichtlichen G+...
[KERNEL][Nexus 6] Code_Blue r196 [Lollipop 5.1 / 5.0.* & CM12 (deprecated)][04.04.2015]
G+ Community im Opener ergänzt.
[size=18]Code_Blue r212 [/size][size=18]
All right crew!
This is for Lollipop 5.1 ROMs only.The zip uses anykernel installer, this means it uses previously installed ROM kernel Ramdisk.
If already have Code_Blue or ROM default kernel installed just flash over.
If you come from other kernel dirty flash you ROM and flash Code_Blue after.What is barebone edition?
A new branch I started with full rebase, high power, top battery, trim fat, all the goodies in.
Possible? Yes!Keep it real, keep it true, keep it #Code_Blue
[/SIZE]
>> Full rebase: welcome to barebone edition era
>> blu_active: add missing bits
>> defconfig: disable sync before suspend, update and cleanup
>> f2fs: upstream changes and fixes
>> power: make sync on suspend optional
>> sched/fair: Implement fast idling of CPUs when the system is partially loaded
>> ASoC: compress: fix memory corruption case
>> PM / devfreq: Return error when tz init fails
>> crypto: arm/aes update NEON AES module to latest OpenSSL version
>> cfq-iosched: Fix wrong children_weight calculation -
Thread abzugeben.
Bei Interesse bitte bei mir melden.
Um den Rest kümmere ich mich.Gruß
All right crew!
Just pushed Code_Blue r222 for Nexus 6
This is for Lollipop 5.1.* ROMs only.
If you come from other kernel dirty flash you ROM and flash Code_Blue after.Changelogs on website
On this release I added a new tunable to blu_active (thanks stratosk for the idea), which exposes low_load_down_threshold (on earlier builds the value was hardcoded).
The default is 10 which keeps freqs at 300MHz if the load is lower than 10%. This also improves the ripple on the 3 lower freq steps.On the shamu there's a new wakelock divider for wlan_rx wakelock and msm_hsic wakelock, which will have an interface for it soon on Adiutor.
"Changelog"
[size=18]Code_Blue r222 (shamu)[/size][size=18][/SIZE]
>> blu_active: add low_load_down_threshold
>> f2fs: upstream updates
>> crypto: updates and optimizations
>> AIO: Don't plug the I/O queue in do_io_submit()
>> msm: vidc: avoid crash due to division by zero
>> clk: qcom: clock-generic: Use DIV_ROUND_CLOSEST for div clock
>> msm: mdss: KCAL: Remove MODULE_DESCRIPTION
>> msm: mdss: increase mdp core clock to match panel pixel clock
>> mm: Fix NULL pointer dereference in madvise(MADV_WILLNEED) support
>> vfs: read file_handle only once in handle_to_path
>> mnt: Prevent pivot_root from creating a loop in the mount tree, Only change user settable mount flags in remount
>> ipv6: Don't reduce hop limit for an interface
>> netfilter: conntrack: disable generic tracking for known protocols
>> eCryptfs: Remove buggy and unnecessary write in file name decode routine
>> tracing/syscalls: Ignore numbers outside NR_syscalls' range
>> hsic: introduce user configurable timeout for msm_hsic_host wakelock, allow wl_divide = 0 to completely disable hsic wake source, avoid keeping the ws activated after sysfs disable
>> bcmdhd: reduce rx wakelock timeout via sysfs node
>> LZ4 : fix the data abort issue
>> pinctrl: msm: prevent bogus wake up from suspend
>> i2c-qup: improve the bus recovery procedure in qup i2c driver -
Das Projekt scheint weiter zu gehen. Gerade bei xda gesehen das der Kernel nun blu spark heißt.
Welcome back to business!!22:37
Den DL gibt's hier:
22:37Gesendet von meinem Nexus 6
Hat er jemanden gefunden der ihm was bezahlt???:eek::eek:
Macht der auch beim N5 weiter?
Wenn du ihm eins kaufst bestimmt:D:D:D
...ich bin heute wieder pöse:eek:
... Wer suchet, der findet. Sorry:blush:
22:37
Lassen wir uns mal überraschen, wann die Drama-Queen wieder einen Anfall oder keine Donations mehr bekommt
Oder die Festplatte abraucht☺
Also, kurzes Fazit mit bluespark b25
Wurde ja bei xda von einigen über den grünen Klee gelobt wegen Akku.
Was soll ich sagen? Akku scheint sehr gut zu sein, habe nach einem Tag (Urlaubstage sind kürzer [emoji6] ) noch 27%Akku und etwa 3 3/4 h DOT.
Ein sehr guter Wert, der meines Erachtens aber deutlich zu Lasten der performance geht... Habe einige laggs gemerkt heute, u.a. bei twitter, beim APP drawer und beim entsperren
Alles in allem für Akku-junkies Support, aber nicht meines. Denn ich habe jeden Tag oft Möglichkeiten zu laden -
Dann nimm doch mal r26
Ich habe noch keine laggs oder dergleichen bemerkt.
Aber so unterschiedlich sind die Geräte und deren Benutzer. [emoji14]
ungültiger LinkGesendet von meinem Nexus 6
Habe auch den 26er mit der Xenon laufen, bei mir laggt nischt in Verbindung mit dem Seeder (Entropy-Generator).;)
26 probiert, für besser befunden, aber immer noch micro-Ruckler beim scrollen mit Twitter (mein RUCKLER-ANTUTU [emoji6] )
Daher wieder zurück zu Elite kernel...
Der bockt auch sagste?
Für manche ja für manche nein... Vielleicht bin ich ja zu anspruchsvoll...[emoji6] [emoji6] [emoji6]
Ich sagte auch "micro"
