Habe den Kernel mal mit der Pure Nexus ROM am laufen...alles Prima kein Ruckeln
[KERNEL][Nexus 6] Code_Blue r196 [Lollipop 5.1 / 5.0.* & CM12 (deprecated)][04.04.2015]
blu_spark r32
All right crew!
New build is up, enjoy!Quote:
- Build with SaberMod 4.9.4 arm-eabi cortex-a15_neon-vfpv4
 - Revert wifi driver to previous state (Google introduced some changes to N5 and N6 that derped the performance and stability in some situations)
 - Disabled bcl driver (voltage mitigations thresholds, thanks to @hellsgod)
 - Memory compaction and other miscellaneous patches
@Spevil
DL-Link im OP funzt nicht mehr, hier der neue DL -
Ist erledigt, sollte wieder funktionieren.
Wer den Thread übernehmen möchte kann sich gerne bei mir oder einem Moderator melden.
Gesendet von meinem Nexus 6
blu_spark r36
All right crew!
New build is up, go get it!Quote:
- msm: mdss: KCAL: Send a pp display commit when changes are made (thanks @savoca)
 - usb: gadget: Remove moto cdrom sysfs for drivedroid full support
 - usb: gadget: mass_storage: added sysfs entry for cdrom to LUNs (thanks @FrozenCow)
 - PM: Enable asynchronous noirq resume threads to save the resuming time
 - PM / Wakeup: Use rcu callbacks for better performance
 - lz4: fix system halt at boot kernel on x86_64
 - arm: smp: Update the topology masks before calling CPU_STARTING notifier
 - Makefile: sort list of defconfig targets in make help output
 - kbuild: remove warning about "make depend"
 - arm: irq: Tone down kernel logging
All right crew! Blu_spark_41
New build is up, mellow style ;p
ZitatAlles anzeigen* Build with latest SaberMod eabi-4.9-09282015
* Rebased to android-msm-shamu-3.10-marshmallow
* KCAL: Use PCC for negative display mode, Only apply updates on index 0
* Disable Empty Learning feature
* Removed forced permissive mode
* Removed wakelock switches
* General cleanup
root is now available in enforced mode thanks to chainfire.
1. Just go to SuperSU thread and download the kernel zip MCR Modpack
2. Extract the boot.img (not a flashable zip)
3. go to recovery, flash boot.img, flash SuperSU v2.50, flash "Blue">blu_spark<
4. ProfitGesendet von meinem Nexus 6
blu_spark r45
All right crew!New build is up, enjoy
Quote:
- lowmemorykiller: adapt to vmpressure (dynamic LMK from CAF)
 - lowmemorykiller: squash task adj rbtree optimization from Motorola and other upstream updates
 - mm: vmpressure: upstream updates
 - Don't reset keys pressed at suspend time from Atlantis
 - tcp_cubic: do not set epoch_start in the future, better follow cubic curve after idle period
 - Improvements on RAMdisk and install routines
blu_spark r50
All right crew!
New build is up, lot's of updates, enjoy Zitattcp: fix timing issue in CUBIC slope calculation, fix the range of delayed_ackmsm: kgsl: Ratelimit memory related error messages, add GFP_NO_ZONELIST_SCAN to large order allocations, Call adreno_spin_idle instead of kgsl_idle, Vote for new IRQ specific QoS requestmsm: mdss: properly handle panel on and off, reduce log level when ping pong timeout happens, fix ret value during error case, remove ov_lock for rotator sessions, align frame buffer size to PAGE_SIZE, Adjust fence timeouts, update max fence wait timeout for all acquire fencecpufreq: Check current frequency in device driverInput: optimize events_per_packet count calculationext4: rate limit printk in buffer_io_error()msm: cpp: Limit the rate of pop buffer messagesnet: fix iterating over hashtable in tcp_nuke_addr()arm/dt:8084: Disable always-on for pma8084_lvs4mm: use managed_pages to calculate default zonelist order, fix sleeping function warning from __put_anon_vma, fix use-after-free in __put_anon_vma, correctly update zone->managed_pages, use a dedicated lock to protect totalram_pages and zone->managed_pages, accurately calculate zone->managed_pages for highmem zones, Make the default CMA region not reserved by default, don't limit default CMA region only to low memory, add GFP_NO_ZONELIST_SCAN to skip fallback zoneshrtimer: Prevent stale expiry time in hrtimer_interrupt()ion: retry during race with shrinking/allocating, add GFP_NO_ZONELIST_SCAN to large order allocationsnohz: Convert a few places to use local per cpu accessesfs: Workaround the compiler's bad optimizationnetfilter: xt_socket: use IP early demuxclk: qcom: Use rt mutexes for the rpm and voter clock locksipv4: try to cache dst_entries which would cause a redirect, try to cache dst_entries which would cause a redirectlist: introduce list_next_entry() and list_prev_entry()qcom-cpufreq: Restore CPU frequency during resumestaging: ion: fix corruption of ion_import_dma_bufipc/sem.c: fully initialize sem_array before making it visibleselinux: do not check open perm on ftruncate callFix NULL pointer dereference in tcp_nuke_addr.sched/balancing: Prevent the reselection of a previous env.dst_cpu if some tasks are pinnedsched/fair: Implement fast idling of CPUs when the system is partially loadedmmc: sdhci: Vote for new IRQ specific QoS requestirq: Allow multiple clients to register for irq affinity notificationQos: Pass the list of cpus with affected qos to notifer, Enhance framework to support cpu/irq specific QoS requests, Modify data structures and function arguments for scalability.audit: Mute userspace and kernel audit logsfs/namei.c: fix potential memory leak in path_lookupatASoC: msm: qdsp6v2: Suppress spammy logRevert moto LMK merges
Don't forget to hit thanksOP bei XDA
Der Kernel wird leider nicht mehr weiter supported bzw weiterentwickelt.
Hi guys.<br />
<br />
I don't have access to this device anymore, so this thread will not be updated.<br />
<br />
Thanks!Gesendet von meinem Nexus 6
