Chroma is a lightweight AOSP ROM focused on battery, performance and stability.
The philosophy of Chroma is to stay relatively close to Google's stock Lollipop with additions of essential features that you'd normally see on most custom ROMs.
[size=18]Features[/SIZE]
Franco Kernel
Layers Support
Native LED Notifications built-in (solid, limited to RGB colors)
Status Bar Customization:
Battery Style (Icon Portrait/Landscape, Circle, Text, Hide) and Battery Percentage
Clock & Date (Show/Hide, Color, Alignment, AM/PM, Show/Hide Date, Date Style, Date Format)
Brightness Control (long press status bar to change brightness)
Double-tap status bar to turn device screen off
Quick pull-down on left/right side to pull down tiles
Long press tiles actions
Pressing on clock or date on status bar opens up Clock, Calendar
Show/hide notification count on status bar
Tile customizations (LTE, Screenshot, Sync, etc tiles)
Enlarge 1st row, show 4 tiles per row, show/hide brightness slider
Heads up notifications
Network traffic indicator
Navigation bar customization
Rearrange navigation bar to your likings
Navigation bar height (48/44/40/36/32/28/24/20/0dp)
Navigation button tint
Show/hide arrow keys while typing
Kill app back button
Navigation ring customizations
Clear all recents button (enable/disable) and location (top left, top right, top center, bottom left, bottom right, bottom center)
Clear all task (dismiss all task or ignore the foreground task)
Lock screen customization
Power menu customization (power off, reboot, screenshot, airplane mode)
Advanced Reboot (reboot/soft reboot/recovery/bootloader)
Volume rocker customization:
Wake device with volume keys when screen off
Long press volume up/down keys to skip track when screen off
Volume key adjustment sound (enable/disable)
Other:
A large number of optimizations and memory leak fixes
Ambient display controls
Animated expandable volume panel
Long press recents to swap back to previous app
AOSP Gallery2 with material design
Prevent accidental wake (proximity sensor before waking screen)
... and more (see changelog)
[size=18]Anleitung[/SIZE]
[size=14]Pre-requisites:[/SIZE][size=18]unlocked bootloader[/SIZE][size=14], [/SIZE][size=18]latest TWRP recovery[/SIZE]
[size=14]1. Download ROM, Gapps, SuperSU and put it on the phone's internal storage.
2. Boot into TWRP recovery.
3. Coming from a different ROM? Perform a factory reset using TWRP. If you're upgrading from Chroma ROM, proceed to dirty flash (nandroid backup before flashing is a good idea)
4. Flash ROM, GApps, SuperSU, Kernel (Optional), VomerTweaks (Optional)
5. Reboot and enjoy.[/SIZE]
[size=18]
Download
[/SIZE]
All Chroma Builds
G+ Community
https://plus.google.com/communities/100877567555105149232
Gapps Sammlung
SuperSU Stable & BETA
Layers/RRO Themes Sammlung
https://www.android-port.de/themen/theme-l…hemes-vor.6628/
[COLOR=#ff0000]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.
ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht.[/COLOR]
