Ich krieg Better Battery Stats nicht installiert. Hat das Problem jemand auch?
Gibt es ansonsten andere ähnliche Apps?
[ROM][N6] Chroma [5.1.1r4][LMY47X][Native LED][VoLTE][Layers][02.08.2015]
BBS muss als System-App installiert werden, damit es funktioniert. Lösche mal die bisherige Datei und flashe dieses BBS.zip im Recovery, danach das Update auf die aktuelle Version im Playstore machen und BBS sollte funktionieren.
Ansonsten verwende ich immer noch Wakelock Detector aus dem Playstore.
Update ist raus
Quelle: xda
[Hide]
Chroma 06/05/2015 Nexus 6 (shamu)
Quote:
Added: Double tap to sleep anywhere on the lock screen
Added: Support for Visual Voicemail for Verizon Wireless (shamu)
Bugfix: An issue where text is not showing up on first instance for Increasing Ring
Bugfix: An issue where if a user does not flashes GApps pulldown/home button/etc does not work (need confirmation)
Bugfix: Gallery2 - Fix crash when Bluetooth service is disabled
Bugfix: Google Now not working on shamu, fixed now
Bugfix: Increasing ringtone volume preview behavior
Bugfix: Some apps were ignoring the custom DPI scaling
Bugfix: VoLTE would not work when using T-Mobile LYZ28E radio .14R (shamu)
DeskClock: Remove "hot pink" on switches
Updated: Better handling of expanded volume sliders
Updated: Code cleanup across a number of components in the ROM
Updated: Expanded volume slider now uses Android M drawable
Updated: Increase brightness faster if ambient light is brightening quickly
Updated: Proprietary binaries to LYZ28E (shamu)Changelog:*Primary (Recommended)
Download:*LG-SupportIt'll be a Nexus 6 exclusive for the first couple of hours to let the Nexus 6 users have a "go" at the build to ensure that there aren't any bugs. If all goes well, then the sources will be pushed as well as compilation for other officially supported devices.
[/hide]
Neues update 17/06
Komplette rewrite der ROM, egal was das heißen mag, wird ein full wipe empfohlen, wenn man nicht auf den letzten builds war...
Zitat zephiK:
Chroma 06/17/2015 Nexus 6 (shamu)
This is a full rewrite of the ROM. A full wipe is required if you did not flash the preview builds. Some features are not included and are meant to not be included, some features will be coming back in a future build (don't ask or request which ones).If you used a DPI other than stock using the DPI changer built in settings,
I suggest going back to the default DPI before you flash the new build to prevent boot loopsDownload: bokrom-gapps-full-hammerhead
Ja die haben wohl die letzten 5 Tage ihre Sourcen komplett neu gemacht.
Chroma 20/06 ist draußen.
Download wie immer im opener.Changenlog laut xda:
06/20/2015If you changed your DPI using the built-in DPI switcher. Revert back to 560 DPI as the built-in DPI changer is no longer available as of 06/20. This is removed due to instability (mainly bootloops when people dirty flash the ROM with the custom DPI intact). After you wipe and the DPI still doesn’t change? Do a clean wipe.
Added: Ability to disable advanced reboot (developer options)
Added: Ability to disable bar color in battery saver mode
Added: Ability to disable navigation ring
Added: National data roaming
Added: Navigation ring customization
Added: Power button for navigation bar
Added: Status bar header long click actions
Battery - battery saver settings
Date - Set calendar event
Time - Set alarm
Settings - QS tiles settings
Weather - LockClock settings
Added: Tiles
Battery saver
Heads up
Screenshot
Screen timeout
Sync
Bugfix: Clear all recents in bottom right now works
Bugfix: Fix there is no sounds and delays 1s when pressing "Touch sounds" sometimes
Removed: LCD density changer -- use texdroider, change in build.prop etc
Update!
Link und changenlog kommt, wenn ist etwas mehr Zeit habe. Bitte um Verständnis...Download wie immer im opener aktuell.
Letztes update des dev:
Man echt schade, optipop geht den Bach runter, Chroma ist wohl auch durch...Was ist denn da los?
Deswegen habe ich @fraz14 's Slim laufen. [emoji14]
Gesendet von meinem Nexus 6
Holla, der @fraz14 haut ja ständig neue builds raus!
Changelog liest sich super, hat sich ja ne menge getan in den letzten Wochen, im Grunde alles drin was man mag und lieb gewonnen hat. -
Na dann hopp hopp!!
Rom läuft echt super!!Gesendet von meinem Nexus 6
Ne, dat täuscht:D
Normal 1x pro Woche Update. Maximal 2x. Soll ja nicht in Stress ausarten:D -
Wo kann man denn den Changelog vom Herrn fraz finden
hab gerade mal die ROM drauf
ok gefunden
woher weiß man denn, wenn es was neues gibt -
Hm, gut Frage:D
Immer mal in meine Sig gucken:D -
ok gefunden
Cool, mir ging gerade die selbe Frage im Kopf rum (bzgl neuer build). Pushbullet wäre zum Beispiel super (sofern man nicht vergisst es zu pushen).
Ein eigener Thread wäre bestimmt super, magst nicht machen, @fraz?@depetti73
Wie ist dein Eindruck, im Vergleich zu optipop? Die recents sind ja die von Slim, dürften dir also eher nicht gefallen. Aber wie ist es sonst? -
Der Rest gefällt mir bis jetzt recht gut...vorallem wettet im lock....
Is alles da was ich brauche
Hatte auf Grund von den Changelogs eben auch den Eindruck, dass alles von optipop mit drin ist und sogar Wetter im lockscreen. Werd ich dann wohl doch mal flashen. Einzig blöd finde ich die File Struktur, man kann nicht vorher Sachen ändern (apps entfernen etc).
Recents ist doch eh Wurscht. Kann man doch ausschalten dann hat man die normalen.
Ach cool! Wußte ich nicht und finde die normalen einfach etwas stylischer. Und sonst, fraz? Eigenen thread? Einen Bereich nur für dich?[emoji6]
