Was meinst du??
Verstehe dich nicht so ganz.
[ROM][N6] Chroma [5.1.1r4][LMY47X][Native LED][VoLTE][Layers][02.08.2015]
Achtung!
Update timeChroma Android 5.1.0 Series
03/31/2015
Added: Back phone notification LED settings backend
Added: Disable quick pull down on secure lock screen
Added: Expanded desktop (settings > display)
Added: Expandable volume panel with animations
Added: Link/unlink ring and notification volumes (settings > sound & notifications)
Added: Missing layer commits for quick setting settings
Added: Notifications tile
Added: Torch SEPolicy service context
Added: Option to show 4 tiles per row
Bluetooth: Sort Bluetooth devices in quick settings by name
Fixed: Large number of fixes from 5.0.2 Chroma and AOSP. View github for the fixes in full detail
HeadsUp: Swipe options
left swipe: dismissright swipe: put into backgroundswipe down: opens notification drawer and moves the notification into it
Auch hier ist der Thread wieder aktuell.
Und hier die "Oster-Edition" von Chroma:
Chroma 04/04/2015:Changelog: GENIAL!!! Wat so ein "geschultes" Themer Auge sieht
Download: Cataclysm Beta update Apr 04, 2015BUG: When ambient display is on, volume skip track does not work. With ambient display off, it works as intended. Volume wake now properly turns on/off when ambient display is on -- will fix this at another time.
Update verfügbar
ZitatAlles anzeigen04/05/2015
AFTER FLASHING ZIP, WIPE DALVIK CACHE IN TWRP THEN REBOOT
For full explanation read, THIS!!!
Added: ART optimization to everything -- read HERE for details
Added: Facelock build.prop additions
Added: Support for bypassing setup wizard and Google Service delay -- readHERE
Added: Support for AMR Wideband
Added: Tethering build.prop additions
Nexus 4 & Nexus 5:
Added: Chroma wallpaper and boot animation (thanks to @boysetsfire on XDA)
Added: Restore Franco Kernel as stock kernel on Nexus 5
Hehe, da bin ich auch gerade 20+ Seiten am nachlesen...interessant mit der ART-Beschleunigung.
Habe die build.prop jetzt auch mal beim Euphoria um die beiden Einträge erweitert, wipe cache/davik und reboot...kommt mir schon so vor, als ob das noch mal nen kleinen Schub gebracht hat.;)
Diese zwei Zeilen in die build.prop einfügen, danach im TWRP cache und dalvik wipen:
dalvik.vm.image-dex2oat-filter=everything
dalvik.vm.dex2oat-filter=everythingDas gilt natürlich nur für andere Roms, die diesen Tweak noch nicht drin haben...die neuste Chroma hat das ja bereits inklusive.;-)
Lohnt sich der Umstieg von der Terminus oder läuft bei der Chroma immer noch nicht alles?
Eben aufn N5 mit Euphoria eingerichtet ... WooooW!!! Wirklich spürbar - besonders PlayStore etc ... große Apps.
THX
LOL, mein Mega hat dadurch auch 2 Prozessor-Kerne mehr bekommen...;)
Ist es egal an welcher Stelle ich das einfüge oder ganz am Schluss?
Ganz unten.
Es gab wieder ein Update.
Zitatr2 hotfix: Voice over LTE works once again
Update Chroma 04.07.:
Changelog
Added: Heads up notifications
Added: Long press rotation tile
Added: New tiles- Heads Up
- Screenshot
- Sync
Added: Statusbar clock can now be aligned to the left
Fixed: Some application/games would not load properly due to this commit
Updated: Adjustments to expanded desktop and battery saver tiles
Updated: Clear all recents app default location is now on the top right
Updated: Mirroring layout on RTL languagesDownload: 【Theme】【5.0 lollipop】Black Material Theme【Cataclysm 4/Apr】
- Heads Up
Leider immer noch ohne lautlos- Modus
Das scheint bei den Devs leider an unterster Stelle zu stehen mit dem Lautlos-Modus...
Update verfügbar!!!
10.04.2015
[SIZE="4"][COLOR="Red"]It is imperative that you use the kernel that is supplied with the ROM; otherwise, you will lose all of changes on the SEPolicy[/COLOR][/SIZE].Some of the changes on sepolicy include messenger mms, user profile picture not being changed
- https://github.com/Chroma-Aosp/an…b2128eb488320db
- https://github.com/Chroma-Aosp/an…a4df897decc5084
Added: Number of bug fixes from AOSP repository
Fix: Browsers would randomly crash, this should no longer happen
Fix: When contents are hidden on a secure lock screen, text is no longer white
Fix: Random missing tiles when leaving detailed view
LockClock: New material icon
Updated: French translations (thanks RenaudR)
Updated: Large number of optimizations, reverts, performance tweaks, sepolicy changes, code cleanup
Updated: Quick setting tile changes (resize dual tile, padding issue fix)
Updated: shamu - Franco Kernel r25 to my unofficial Kernel r26 (+dt2w/s2w/s2s)
all other nexus devices (except manta/N10) - latest Franco Kernel
Version lädt gerade, werde berichten.
Mit lautlos Modus?
Keine Ahnung, flashe gleich erst.
