Und druff ... Mit slimgapps und franco
Macht nen guten Eindruck ![]()
...kannst uns ruhig glauben ![]()
Update 02.04.
Alright, update for chroma for the n4 and n5.
These do not have Franco in them at all and instead are using the prebuilt aosp kernels
Synced upstream with zephik
Added: HSPA+ indicators
Added: Power control widget
Added: Volume key cursor control
Fixed: Build number previously appeared as LMY47I test-keys
Fixed: Some applications were encountering FC's by a change in the RenderScript
Fixed: Quick unlock toggle was not properly working
Fixed: Shuffle pin was not properly working
Updated: Performance and optimization tweaks
Nexus 4 users, we still have the wallpaper not loading/or being able to load the wallpaper picker.
This will cause a force close of systemui if you do not have a wallpaper set. If you are dirty flashing, set a wallpaper before you flash. Clean flashing, take a pic or download something and go into gallery and set it as your wallpaper on your first clean boot otherwise you will not be able to restart the ROM (this is a temporary work around till I get this fixed)
Nexus 5 users, you can flash Franco over this and apparently code blue, otherwise use a any kernel kernel like hell score or elementalx
Nexus 4 users, since the ramdisks of full boot image kernels are not updated for 5.1, only flash any kernel kernels
Update 02.04.
BTW, here is the newest banks gapps
http://fitsnugly.euroskank.com/?rom=banks&device=gapps[/QUOTE]
Hab die rom auch heute morgen geflasht, bisher alles super [emoji106]
Das neue update kann ich einfach drüber Bügeln?
Mit dem Update scheinen irgendwie die Optionen
- Benachrichtigungslicht (für einzelne Apps)
- Batterielicht
verschwunden zu sein ... Mal abwarten, ob das gefixt wird...im Changelog steht ja nichts dazu drin.
Außerdem war die Option ja eh erst mit dem Update vom 31.3. verteilt worden...Mal gucken, was Sykopompos so schreibt.
Hab´s schon mal bei xda gepostet
Ja ist mir auch schon aufgefallen. Hoffe das es wieder rein kommt.
Hab auf xda gelesen das einige mit der Playstation app Probleme haben fc. Gleiches Problem habe ich auch. Gibt's dafür eine Lösung?
De installieren?
Logcat?
Hatte auch zu Anfang mit einigen Apps Probleme. Neueste playservice apk hat geholfen. Danach lief alles
04-03 20:16:00.519 W/ActivityManager(752): Scheduling restart of crashed service com.scee.psxandroid/com.playstation.companionutil.PushNotificationService in 7062ms
04-03 20:16:07.612 I/ActivityManager(752): Start proc 10422:com.scee.psxandroid/u0a149 for service com.scee.psxandroid/com.playstation.companionutil.PushNotificationService
Deinstall habe ich schon gemacht.
Ist das die richtige apk Version: 7.0.99 (1809214-448) (7099448) for Android 5.0+ (Lollipop, API 21)
Uploaded: April 1, 2015 at 2:44AM GMT+0200
File size: 35.59 MB
Falls das eine Frage ist welche PlayService apk??? :X3:
Dann mal hier weiter mein bester >> https://www.android-port.de/themen/aktuell…app.5968/page-4
Und dort würdest dann sowas finden >>
ZitatTo figure out the right version of Google Play Services for your Android device, go to Settings -> Apps -> Google Play services, and look at the last 3 numbers in the parentheses. You'll see something like -XYY where X is 0 for pre-Lollipop and both 4 and 7 for Lollipop+, and YY is a specific variant id. -738 means you need the APK that has -738, etc.
Note: It seems that -7xx builds became -4xx with Google Play Services 6.5. If you were on -7xx before, you should now install -4xx.
The types are:
- Version number has -X10 - universal armeabi CPU
- Version number has -X12 - 160 DPI & armeabi CPU
- Version number has -X14 - 240 DPI & armeabi CPU
- Version number has -X30 - universal armeabi-v7a CPU
- Version number has -X32 - 160 DPI & armeabi-v7a CPU
- Version number has -X34 - 240 DPI & armeabi-v7a CPU
- Version number has -X36 - 320 DPI & armeabi-v7a CPU
- Version number has -X38 - 480 DPI & armeabi-v7a CPU
- Version number has -X46 - 320 DPI & arm64-v8a CPU
- Version number has -X70 - x86 CPU
Dies kannst du bei dir im Phone nachgucken:
Einstellungen >> Apps >> Alle >> Play Dienste
Hab die gleiche Version wie du auf dem Screenshot. Ist das dann die neuste?
LOL @MuggelPu ist der erste der sein Smartphone up2date hat!!
[size=14]chroma_hammerhead-ota-2015-04-04.zip TEST BUILD ;)[/SIZE]
ZitatN5 chroma users, here is a new test build
Cataclysm Beta update Apr 04, 2015Still no Franco kernel here so led notifications probably won't be an option, I'll add that into the next build, doing some tuning right now
This is in relation to the question I asked last night about would you be OK with a slightly longer optimizing apps at boot if you got better performance out of it.
We are talking an extra minute or 2 here depending on your apps.
Make sure you select to wipe your dalvik-cache after flashing. You want to force it to make new more optimized oat files
Danke. Na dann wollen wir mal gucken, ob das wirklich Speed bringt:P
rennt wie Schmitz Katze ![]()
Update verfügbar.
ZitatAlles anzeigen04/05/2015
AFTER FLASHING ZIP, WIPE DALVIK CACHE IN TWRP THEN REBOOT
For full explanation read, THIS!!!
Added: ART optimization to everything -- read HERE for details
Added: Facelock build.prop additions
Added: Support for bypassing setup wizard and Google Service delay -- readHERE
Added: Support for AMR Wideband
Added: Tethering build.prop additions
Nexus 4 & Nexus 5:
Added: Chroma wallpaper and boot animation (thanks to @boysetsfire on XDA)
Added: Restore Franco Kernel as stock kernel on Nexus 5
OP Update ...
Das Chroma Update für unser N5 braucht ein weing Zeit... das warten wird sich bestimmt lohnen ![]()
ZitatJust so everyone know, I won't be releasing a current update to match zephik's n6 update at this time.
I got a lot of under the hood work to do at the moment with devices and source in general that I want to get done before spending time updating. I want to address each device properly before giving back that part to zephik
(That means he will have to update to my changes too because I will be doing a lot of under the hood work in general that will effect the n6 too)
Zitatsystem/core stuff, cleaning up sepolicy, cleaning up a lot of log spam and camera stuff (mako, hammerhead, flo, shamu) probably going to convert Franco kernel over to a init.d setup for those that want to use different kernels
