[ROM][6P][6.0.1_r17]★ Pure Nexus ★ Layers/CMTE | Fi | WiFi Calling ★[03/08/16]
  • [size=14][COLOR=#4da6ff] The Pure Nexus Project
    About:
    The Pure Nexus Project aims to bring stability and features to your Nexus device, while keeping Google's vision in line and not straying too far away from that. If you are looking for a stable ROM with true tested features and minimal bugs, then this is the place to be.
    [/COLOR][/SIZE]
    Features:
    "Click To Hide Content"
    Code:
    -General
    *Based on AOSP Android 6.0.1_r17
    *Pre-rooted with SuperSU 2.65
    *SELinux Enforcing
    *Busybox
    *Init.d support
    *Addon.d support
    *T-Mobile US WiFi Calling + Project Fi Support
    *Fully Working VoLTE
    *Native Sprint PRL/Profile update
    *Native ntfs and exfat support
    *Full Layers and Theme engine support
    *Google sounds from factory image not the horrible AOSP ones
    *Googles marshmallow wallpapers added to wallpaper picker
    *Advanced Reboot menu enabled by default
    *Advanced rotation settings
    *Enabled Developer settings by default
    *Enabled option to use multi-window mode
    *Enabled click/longclick on notification panel header items
    *Disabled forced encryption
    *Disabled Device modification warning
    *Disabled Tethering checks
    *Disabled Full screen keyboard in landscape
    *Show apps being optimized during initial boot
    *Bug fix's and stability improvements
    *UI Improvements (fixed a bunch google forgot to materialize)
    *Download Speed in download notifications
    *Scrolling cache improvements
    *Seek-bar animation speed and font size control
    *Hostname customization
    *Adb over wifi access
    *Full 3-Minit battery support no mods needed
    *Kitkat style silent mode is now default
    *Added headset icon attached icon in statusbar
    *Added PureAmbient display options
    *Added Full CAF Based AppOps
    *Added ability to see app version when sideloading app
    *Added ability to launch app from app info sceen
    *Added app package name to app info screen
    *Added ability to disable battery saver color in nav/statusbars
    *Added ability to launch purenexus settings from notification drawer (longpress settings icon)
    *Added ability to customize Settings dashboard columns, dashboard text lines, dashboard dividers
    *Native Dialer lookup in the aosp dialer
    *Increasing ringtone option
    *Incall vibration options
    *Proximity speakerphone option
    *National Data roaming option
    *Call/Message blocking
    *Link/Unlink Notification ringtone option
    *Added Native Google Double tap to wake option
    *Added Standalone documents ui file manager
    *Added Special keys to all keyboard keys
    *Added more smileys to the aosp keyboard
    *Removed googles bug report option
    *Removed googles SystemUpdate option
    *Removed googles legal information
    -PureNexus Settings
    Lock Screen
    *Option to customize lockscreen shortcuts
    *Option to customize lockscreen weather
    *Option to customize lockscreen clock font
    *Option to disable fingerprint authorization vibration
    *Long press power for torch
    *double tap anywhere to sleep
    *Option to disable lockscreen media art
    *Scramble pin layout
    *Quick pin unlock
    *options to unlock straight to pin/pattern/password entry
    *option to hide lockscreen clock
    *option to hide lockscreen date
    *option to hide lockscreen alarm text
    *Option to control max notifications on the lockscreen
    *option to set the alpha of lockscreen and lockscreen security bouncer
    *Lockscreeen Wallpaper (add/crop/delete)
    Notification Drawer
    *Weather
    *Force Expanded Notifications
    *quick settings pulldown (left,right,always)
    *smart pulldown (no ongoing, no dismissable)
    *brightness slider on/off toggle
    *option for time aware contexual notification header images
    *option for poly hd notification header images
    *fully customizable quick settings with now up to 30 custom tiles
    *option to enable or disable the top two main quicksettings tiles
    *option to enable 3/4/5 quick settings tiles per row
    *option for advanced location in location quick setting tile
    *option to enable vibration on quick settings tiles
    *option to disable quick settings on secure lockscreen
    Recent Apps
    *Immersive recents (stock, full screen, statusbar only, navbar only)
    *Clear all recents toggle
    *Clear all recents location option
    *Clear all recents but last app toggle
    *Recent searchbar on/off toggle
    *slim recents and slim recent options
    Statusbar
    *Battery customization (stock, landscape, circle, dotted circle, text, none)
    *Battery percent options (hidden, inside the icon, next to the icon)
    *Battery Bar options (location, color, style, thickness, anitmation)
    *Carrier Text customization (text placement, custom text)
    *Clock customization (position, am/pm, date, date position, date style, date format)
    *Network traffic meter options (disabled/incoming/outgoing/both, units displayed, update interval, hide arrows, autohide, autohidethreshold)
    *Status-bar options (purenexus icon, notification counter, double-tap to sleep, statusbar brightness control)
    *Option to disable headset icon, vibrate/silent icon, vpn icon in statusbar
    *Option to disale bluetooth icon in statusbar when not connected
    Navigation Bar
    *Enable/disable
    *IME toggle
    *Option for arrow cursor keys
    *Option for double tap navbar to sleep
    *Long-press back to kill toggle
    *option to configure back kill delay
    *Long-press recents for last app toggle
    *Navigation bar size customization (width, height, length)
    *Navigation bar customization (placement, buttons)
    PowerMenu
    *Option to disable on secure lock
    *Add/remove (reboot, screenshot, screen-record, airplane mode, user switcher,settings shortcut, search, voice search, lock now, sound panel)
    Volume Rocker
    *Volume key wake
    *Volume key music control
    *Volume key keyboard cursor control
    *Volume button swap toggle
    *Control media volume anytime toggle
    *Option to allow volume down in silent to enter do not disturb
    *Option to allow volume up in do not disturb to exit do not disturb
    *Options to control volume steps on the fly
    Display
    *Expanded desktop options
    *option to enable/disable wake on plug
    *LED controls
    Media & Notifications
    *option to ignore interruptions during media playback
    *option to disable camera shutter sound
    *option to disable double tap camera vibration
    *option to disable heads up notifications globally
    *option to lower the amount of notifications an app can make in alloted time
    *option to invert the ambient display notifications
    *option to disable low battery notification
    *Option to disable battery saver notification
    cLock Settings
    *Customize the cLock widget
    Tools and info
    *device info
    *battery history
    *usage statistics
    *wifi info
    *build.prop editor
    *fi switch tools (if project fi sim is installed)
    Downloads & Changelog:
    "Click TO SHOW CONTENT"
    Changelog: Donate link
    Rom Builds: Donate link
    Highly Suggested Gapps - PureNexus Gapps: Donate link
    Google Dialer - needed for Fi wifi calling: ungültiger Link
    Vendor Images(flashable by twrp image option): ungültiger Link
    "Useful Links"
    Detailed Installation instructions (By @nathanchance) nathanchance
    Frequently Asked Questions (By @nathanchance) nathanchance
    PureNexus User Signatures (By @malybru) malybru
    [COLOR=#ff0000]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.
    ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht.[/COLOR]
    Pixel 3 XL 64GB/crosshatch
    N6/64GB/ shamu
    Credendo vides y buena suerte
    4 Mal editiert, zuletzt von Jordi_Lobo (13. März 2016 um 08:42)
  • Update:
    03/15 Release
    • Both Branches:
      • Feature: added flip to mute/reject call
      • Feature: add option to disable fullscreen keyboard
      • Fix: issue with password manager apps not working
      • Fix: issue with supersu not showing up on dirty flash
      • Fix: issue where app ops title text wasn't visible on first menu
      • Fix: dvorak keyboard issues should be up to date now
      • Change: revert aosp messaging back to google messenger
      • Update: to latest aosp source 6.0.1_r22
      • Update: proprietary binaries for 5x/6p
      • Update: kernel source for 5x/6p
      • Update: SuperSU to 2.68
    Downloads
  • Update
    04/07 Release
    • Both Branches:
      • Feature: add option for torch in powermenu
      • Feature: add wireless charger sound for wired chargers as well
      • Feature: added caffeine quicksettings tile
      • Feature: added an option to force heads up in all apps
      • Feature: added an option to adjust the timeout of heads up notifications
      • Feature: added an option to force heads up in certain apps (whitelist)
      • Feature: added an option to turn off heads up from certain apps (blacklist)
      • Feature: added an option to turn off heads up in certain apps (do not disturb)
      • Fix: blacklist force close when clicking on call details with restricting unknown numbers
      • Fix: for sometimes not launching recent apps on first click
      • Fix: out of memory error issue in incallui
      • Fix: issue where bluetooth icon would be stuck on even when disconnected
      • Fix: issue when casting from settings/quick settings would cause a nasty npe/repeat ui crash
      • Fix: center empty text when bluetooth and wifi don't have any devices available
      • Fix: various carrier related issues on nexus 5X/6P should also fix “EE” wifi calling
      • Fix: crash in dialer when setting reverse lookup to yellow pages
      • Fix: generated a pure nexus api key for openweather so it should now work all the time
      • Change: improved heads up toggle now multiuser aware and is standalone from google implementation
      • Change: moved all secure lockscreen mods into a secure category and don't show when insecure
      • Change: move lockscreen weather and clock items into a lockscreen item menu
      • Change: expose package installer tab background color for themers
      • Change: expose back arrow tint color in contacts common for themers
      • Change: expose letter tile colors in contact commons for themers
      • Change: added expand/collapse animation to call log detail view
      • Change: some preparation for an upcoming change to purenexus setting
      • Removed: removed bluetooth only when connected toggle it was causing icon issues
      • Removed: less frequent notifications sound mod was killing notifications in various apps
      • Removed: audio ducking modification as it didnt work for alot of apps and was causing volume sticking
      • Update: all proprietary binaries for Nexus 5/5x/6/6P/7-LTE
      • Update: kernel source for all devices
    • CMTE Branch:
      • Fix: layout in theme chooser app for tablets
      • Fix: unexposed dialer separator line in phonecommon
      • Fix: issue where updating a boatload of apps at once would cause cmte watchdog to crash
      • Change: inflate notifications with apps theme
      • Change: theme tile: sort themes and fix default theme option
      • Change: expose hardcoded storage colors in settings for themers
      • Change: break out text color from commonly used color in settings
      • Change: expose settings dashboard margin and background color for themers
      • Change: expose single panel button text color in settings for themers
