So Leute freut euch auf das nächste build. Das ist mit großem Abstand das schnellste, was ich je geflashed habe.
Be excited for next build. This is by far the fastest that I ever flashed on any device.
...and even on my side: SMS is now working ![]()
I think the battery saving feature is missbehaving. When turned on it lowers the clock to 960 mhz but when turned off it stays at that frequency until i reboot my device.
Probably. Don't use it.
Only if someone didn't see it :
Download per Kaspersky Cloud
I know that you don´t use sound mods. But maybe someone else use viper4android...
I´ve a strange behavior with this mod: It works very well on OMP. The only thing that doesn´t work: During a call the mirco and even the speaker don´t work. Nothing.
Does anyone else noticed that? Does anyone know a way to solve this?
I assume that you use the ARISE sound mod. If yes then it has to do with the tweak.prop files. If not I dont know sorry.
Do you know what to do with that?
If you use ARISE just use guitardedheroes tweak.prop and you will be fine.
I'm using ViperAtmos.... Don't if it's the same solution for this problem
Nope its not cant help you sorry
OK. I'll try ARISE
That's a known issue with most versions of viper...you could try the viperAtmos_4.8_Sony_Beats-Driverless.zip...this worked for me on 2 devices and functioning phone calls.
ViPERAtmos 4.8 Sony Beats Edition Driverless.zip
Thank you
The very fact someone made a mod called guitardedheroes tweak.prop is reason enough for me to never use them....lol
No lol xD the mod is called arise. The guitardedheroes tweak.prop is a file which you rename to tweak.prop which after flashing a tweakprop.zip installs the lines written in it to your build.prop.
Check it out. It is quite nice and completely different to other mods.
I dont do mods and have no need for any audio enhancements.
Do I see OMP for Bullhead??? Yes! Chad, you made my day
 Thank you very much!!!!
But... it's not booting. Clean install, full open gapps, with supersu or without supersu v2.76.zip. (7-7 and 8-7 bullhead build)
